URL for N-HOP-View im LMS 3.1?
lo.mueller
Hi there,
I'd like to integrate the N-HOP-View in our Mgmt-Portal (running on an apache-server).
Is it possible to launch/display N-HOP-View within an IFRAME of a HTML-Page,
and what URL can I use for that?
Thanks for any hint.
Lothar
5 Replies 5
Joe Clarke
Embeddable URLs for portlets are coming in LMS 3.2. due out this summer.
Hi Joe,
thanks for the feedback.
Do you know whether there will be a "paper" documenting the available URLs?
To understand it right, in LMS 3.1 there is no possiblitity to lauch portlets from remote?
Lothar
Yes, the porlets which can be embeddable will be documented. No, this is not possible with LMS 3.1.
Hi there,
searching thru the source-text of PORTAL I discovered following URL for launching N-HOP-View Portlet
"https://:443/campus/qtopo/qtopoUI.jsp?ipaddress=&mode=0&nHops=3&showDFMAlert=on&critical=on&warning=on&information=on&duration=2&units=Min"
This one really works.
Lothar
I'm glad this worked for you. However, this is not the portlet per se. In LMS 3.2, certain portlets will be embeddable as iFrames into other applications (e.g. iGoogle). As a rule, this will not work in LMS 3.1.
