USB Flash As an archive path
andrew.andy316
Hey All,
I am trying to setup archiving to use usbflash0 as the path. However in the path options there is no usbflash0 option altough the a USB drive is attached to the router and can be viewed otherwise with sh usbflash0:.
Are USB drives supported as a destination for config backups using the archive command?
Joe Clarke
No.  The usbflash file system is of type USB_FLASH.  The archive command only supports regular flash file systems, flash disks, and network URLs.
5 Replies 5
Joe Clarke
Thanks much jclarke.
Leo Laohoo
Depends on the firmware of your router.  I haven't tried doing this but I know that in order to boot from a USB, the usbflash0: or usbflash1: is a hidden command.
Hmm interesting. I know sometimes the usbflash command is missing but I am running the lastest IOS so I am inclined to believe the post before yours.
Ty for your help though.
I am correct.  USB_FLASH type file systems are not included in the filter for config archive (yet).
