use EEM to match a portion of output
ciscoworlds
Level 4
Level 4
Hi. I need to use EEM to run a command (actually "show isdn status" command) and inspect the output for the term "MULTIPLE_FRAME_ESTABLISHED" which indicates the L2 status of the E1 line. is there any way to do this with EEM?
and this is sample of the output for this command:
maui-soho-02#show isdn status
Global ISDN Switchtype = basic-ni
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 73, Ces = 2, SAPI = 0, State = TEI_ASSIGNED
TEI = 104, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Spid Status:
TEI 104, ces = 1, state = 6(not initialized)
Joe Clarke
Sure.  Here is some applet code you can use.  This assumes you have preceded the lines with "action X"
cli command "show isdn status"
regexp "MULTIPLE_FRAME_ESTABLISHED" $_cli_result
if $_regexp_result eq 1
 syslog msg "Found Multi frame established"
else
 syslog msg "Did not find multi frame established"
end
