Hello all,
Recently I have been trying to use the mini usb console port that is now on all new switches with my MAC using the instructions in the link bellow. However I have found that when I try to copy/past a config the session frizzes up after 8 lines or so. Has anyone else had this problem and if so how did you fix it?
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/hardware/installation/guide/19cable.html#wp1057624
