Using PA-A3-OC3SMI with ATM access 34Mbps
mariappali
We investigate the possibility to use a PA-A3-OC3SMI with ATM access 34Mbps and connect customers with speeds less than 34Mbps, for example 4Mbps. Is anybody has met with this application. If yes, what was the way that this was succeded?CAn anybody give us some hints?
ebreniz
Level 6
Level 6
We recommend that you do not mix link types (low speed links, high speed links, M2PA/XUA) on the same VIP.
