Using SSH in Topology Services of Cisco Prime 4.2
benjo.rulloda
I tried to access one of the devices in Topology Services in Cisco Prime thru SSH but was unsuccessful. How can I make it work? Do I need to install "putty" on the server just to make it work?
Thanks in advance.
AFROJ AHMAD
Hi ,
Follow the below link to enable SSH from topology services:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_campus_manager/5.2/user/guide_pb/topo.html#wp1328953
note: I have also attached the properties file for you
here are the steps:
To launch the SSH from the topology ,we need to follow the below steps:
>Go to C:\Documents and Settings\
>Use the attached file(campusmgr.properites) that he need to put in the above location.
>Installed Putty
>Made the below change
CMSSH=C:\\PROGRA~1\\putty\\putty.exe
I hope the above info. will help you !!
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks afroz. I will try this.
Hi Afroz,
I need your help because I cannot seem to make it work. I'm using a Window 7 client PC and I copied the
campusmgr file on C:\Users\Administrator. The campusmgr file is still the same with C:\\putty\\putty.exe. I copied my putty file on C:. When I connected to Topology Services, an error appeared. Kindly see attached for the screenshot of
the error.
Hi ,
check these things:
campusmgr.properites,it should a PROP file.
It looks like you copied the putty.exe to the C:\ drive ,however putty folder is missing.
In the example case I created a folder called putty and then I have placed the putty.exe in that folder
Just check the location of the putty and it should work
