02-25-2019 09:17 AM
Does Cisco have Visio stencils for SFP modules such as 10Gbs fiber, 100Gbs, etc?
I've looked all over the visio page on the cisco website, and found modules, but no SFPs.
Solved! Go to Solution.
11-14-2019 06:08 PM - edited 11-14-2019 06:34 PM
Try Visio Cafe...
VSDfx-Generic has a shape for an "Optic SFP+"
The Same shape, as far as I can tell is also in Dell-PowerEdge-RackServers.zip
Note that these are for the SFP's, NOT the transceivers that plug into them! Although, if you need one for those, I'm sure I can create one for you, it's not really all that hard.
10-15-2019 03:34 AM
I would be fine also with the normals SFPs tbh - if I knew where to find them :D
10-15-2019 06:44 PM
10-17-2019 01:26 AM
Try Visio Cafe...
