VLAN DHCP VTP EIGRP
Sanjay916
Hello,  I have a network configuration of 3 MS0 switch, MS0 is acting as dhcp which is giving ips to MS1. MS3 is the internet. However, I am unable to get an ip address for pc4 and pc7 on my MS1 switch interface. Also, I notice all of my pdus are failing when i tried to access MS3 internet. I am not sure what I am doing wrong here. I provided a screenshot of the actual topology and also a script of all my configurations on each switch. Please help Thanks.
MS3 THE INTENET CONFIG SWITCH
int gig0/2
no switchport
ip address 18.0.0.2 255.255.255.252
no shutdown
ip routing
router eigrp 1
network 18.0.0.0 0.0.0.3
network 195.165.85.0
no auto-summary
MS0 CONFIG
ip routing
router eigrp 1
no auto-summary
vtp mode server
vtp domain NDD430
vtp password ciscoserver
int vlan 5
ip address 195.165.85.33 255.255.255.224
no shutdown
int vlan 10
ip address 195.165.85.65 255.255.255.224
no shutdown
int vlan 15
ip address 195.165.85.97 255.255.255.224
no shutdown
int vlan 20
ip address 195.165.85.129 255.255.255.224
no shutdown
int vlan 25
ip address 195.165.85.161 255.255.255.224
no shutdown
int vlan 30
ip address 195.165.85.193 255.255.255.224
no shutdown
spanning-tree vlan 5-30 root primary
interface range fa0/1-4
spanning-tree portfast
interface gig0/1
switchport mode trunk
switchport trunk native vlan 99
switchport trunk allow vlan 5-30
int fa0/1
switchport mode access
switchport access vlan 5
int fa0/2
switchport access vlan 10
int fa0/3
switchport access vlan 15
int fa0/4
switchport access vlan 20
MS0 DHCP CONFIG
ip dhcp pool vlan5
network 195.165.85.32 255.255.255.224
default-router 195.165.85.33
ip dhcp pool vlan10
network 195.165.85.64 255.255.255.224
default-router 195.165.85.65
ip dhcp pool vlan15
network 195.165.85.96 255.255.255.224
default-router 195.165.85.97
ip dhcp pool vlan20
network 195.165.85.128 255.255.255.224
default-router 195.165.85.129
ip dhcp pool vlan25
network 195.165.85.160 255.255.255.224
default-router 195.165.85.161
ip dhcp pool vlan30
network 195.165.85.192 255.255.255.224
default-router 195.165.85.193
ip dhcp excluded-address 195.165.85.33
ip dhcp excluded-address 195.165.85.65
ip dhcp excluded-address 195.165.85.97
ip dhcp excluded-address 195.165.85.129
ip dhcp excluded-address 195.165.85.161
ip dhcp excluded-address 195.165.85.193
MS1:
interface gig0/1
switch(config)#int fa0/1
switchport access vlan 25
int fa0/2
int fa0/3
int fa0/4
switchport access vlan 30
vtp mode client
vtp domain NDD430
vtp password ciscoclient
3 Accepted Solutions
balaji.bandi
It says put unused ports to port 99, not native VLAN as per my understanding.
Also make sure VTP password same - you can have different password for VTP Server and Client.
do you get IP addresses for VLAN 10 and VLAN 15 ?
Try below :
interface gig0/1
no switchport trunk native vlan 99
MS1:
interface gig0/1
Post show vlan from both the switches (MS0 and MS1)
show vtp status - both the switches.
BB
Not sure, some old IOS may see this behaviour.
config t
vlan 25
vlan 30
end
post output.
show vlan
show ip interface brief
show trunk
show span brief
BB
On the internet Switch, you have configured and I do not see any reference interface configured, so configure as per below.
THE INTENET
int gig0/2
no switchport
no shutdown
on MS0 (whatever interface connected you need to configure).
int fax/x   < -- this interface where this is connected to internet
no switchport
ip address 18.0.0.1 255.255.255.252
no shutdown
since you learning, I want to point in a good direction so you can learn the technology help yourself, and help others :
EIGRP and Default route : ( you can also achieve this static route)
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/200279-Configure-Default-route-in-EIGRP.html
BB
10 Replies 10
balaji.bandi
Try below :
interface gig0/1
MS1:
interface gig0/1
BB
Yes, vlan 10 and 15 both have an address from the dhcp. Its just vlan 25 and 30 thats not getting any ip address. I update my script and also included screenshot of vtp status and show vlan.
int gig0/2
no switchport
no shutdown
ip routing
router eigrp 1
no auto-summary
MS0 CONFIG
ip routing
router eigrp 1
no auto-summary
vtp mode server
vtp domain NDD430
vtp password packet3
int vlan 5
no shutdown
int vlan 10
no shutdown
int vlan 15
no shutdown
int vlan 20
no shutdown
int vlan 25
no shutdown
int vlan 30
no shutdown
interface gig0/1
int fa0/1
int fa0/2
int fa0/3
int fa0/4
MS0 DHCP CONFIG
ip dhcp pool vlan5
ip dhcp pool vlan10
ip dhcp pool vlan15
ip dhcp pool vlan20
ip dhcp pool vlan25
ip dhcp pool vlan30
MS1:
interface gig0/1
int fa0/1
int fa0/2
int fa0/3
int fa0/4
vtp mode client
vtp domain NDD430
balaji.bandi
I may be missing something here --- If MS0 is VTP Server  ( i do not see the VLAN 25 and 30 there) - how come I can see the same VLAN in MS1 ?
create VLAN 25 and 30 on MS0 and test
BB
yes, i just notice it too. I just created the vlans and when I input the show vlans command. The vlan 25 and 30 is not showing up. I include a screenshot below.
config t
vlan 25
vlan 30
end
post output.
show vlan
show trunk
show span brief
BB
After i used this command that you provided.
config t
vlan 25
vlan 30
end
Vlan 25 and 30 is now showing in MS0. I am also getting an ip address for for both vlans now. I am not sure why it will only work by using this method. I guess its the ios version.
The only problem am having now is i cannot send packets from the pcs to my internet switch. I think their something wrong in my eigrp routing. I provide some screenshot below of my configurations.
INTERNET SWITCH MS3
int gig0/2
no switchport
no shutdown
ip routing
router eigrp 1
no auto-summary
MSO
ip routing
router eigrp 1
no auto-summary
The first suggestion is to make sure you change the hostname of the devices, a bit confusing every device show as a switch - we hard to get understand the device.
Not sure what you mean by the Internet, is this real internet or 3650(the internet) acting as the internet?
Since your MS0 have all the VLAN and SVI, you need to have static route back and forth to reach each other device.
Since you are using EIGRP ? do you have EIGRP neighbourship, as per output of show ip route, i do not see any eigrp route ?
post full config of both MS0 and Internet switch config to look
also below output
show ip eigrip summary
show ip eigrip neigh
BB
It is not real internet, my 3rd switch MS0 3650 is acting as an internet. i highlighted it in the diagram in blue marking.
The instructions says all pcs show be able to send packets to MS0 3650 which is acting as the internet. The instruction didnt say what kind of routing you should so. So i just use eigrp to setup  routing between MS0 and the internet but it keep failing.
I am not sure if their is an easier way instead of using eigrp. Also, show ip eigrip summary command is not working.
These are my configurations. I also included an screenshots of interface brief and eigrp neigbors
THE INTENET
int gig0/2
no switchport
no shutdown
ip routing
router eigrp 1
no auto-summary
MS0 CONFIG
ip routing
router eigrp 1
no auto-summary
vtp mode server
vtp domain NDD430
int vlan 5
no shutdown
int vlan 10
no shutdown
int vlan 15
no shutdown
int vlan 20
no shutdown
int vlan 25
no shutdown
config t
vlan 25
vlan 30
end
interface gig0/1
int fa0/1
int fa0/2
int fa0/3
int fa0/4
MS0 DHCP CONFIG
ip dhcp pool vlan5
ip dhcp pool vlan10
ip dhcp pool vlan15
ip dhcp pool vlan20
ip dhcp pool vlan25
ip dhcp pool vlan30
MS1:
interface gig0/1
int fa0/1
int fa0/2
int fa0/3
int fa0/4
vtp mode client
vtp domain NDD430
THE INTENET
int gig0/2
no switchport
no shutdown
no switchport
no shutdown
BB
Ok, Thank you. Its working now.
