VLAN reports in LMS 3.1
james-mccarthy
Hey this may be a ridiculous question but I'm running out of ideas. I need to run a report that will display the Voice VLANS on each switchport. We are doing a major phone/VLAN migration and this report will save a lot of time. The current reports I can run only show the current VLAN id and VLAN name. There is nothing that allows me to query the voice vlan on the switchport. All of the edge switches are 48-3750's. Also the phones are Avaya and not Cisco or this would be much simpler.
Any help would be greatly appreciated.
James
Joe Clarke
This is actually not that easy to do.  You can run a User Tracking report, and view All Columns to see the secondary VLANs on ports.  However, this assumes that you have acquired end hosts on these ports.
Yeah I ran the user tracking report and it did show the secondary VLAN. I was hoping for the VLAN id
but I guess I can make that work. Thanks for your help!
