VLANS
mmtantawi
What is the deffrent between create VLAN on the core switch & on the Normal Edge switch ?
Both of them in the 2 cases, will be have the Mode as Server .
so, please update me.
andreabailo
Core switch and VTP server are two separated entity.
Generally The core switch is the VTP server also
coolpopsun
Hi Sir,
Thanx a lot for your support. I am explaning a problem again as I am new
users in cisco, CCNA certified .
I have three switches two 2950 and one 3550 .
3550 is connected to 2950(1st) as a trunk port at both side and another
2950 (2nd) is also connected to 29501st as a trunk.
3550 is in vtp server domain and having 4 vlan---vlan 2 , vlan 3 , vlan
4 and vlan 5.
Now I want in 2950(1st Switch) that 4 pc in vlan 2 and 4 pc in vlan 3.
And in 2950(2nd Switch) 4 pc in vlan 4 and 4 pc in vlan 5 .
When I did all the configuration I found ,not able to ping management IP
also found problem in intervlan routing in switches.
Not able to ping intervlan .What to do I am so confuse that how to do
So please provide me solution : As please use any of the Ip address in
switch as u want and please provide me the fully configuration in both
cisco 3550 server and 2950 client configuration with step by step command
as I am trying this last 3 days but not getting any succsess .
Please do the needful . Please provide complete solution with Ip address
as you want to use . step by step configuration in swtiches _______
I will wait for your kind response.
coolpopsun
As a CCNA, I believe you are already familier with VTP, TRUNK, VLAN and Inter-VLAN routing.
This is the procedure to do inter-vlan routing.
1. On C3550
- Change the interface connected to C2950 to layer 3 port (no switchport)
- Create sub-interface for each vlan
int ga0/25.1(for vlan 1)
ip add x.x.x.x x.x.x.x (define ip address)
2. On C2950
- Define default gateway which is the ip address of vlan 1 in C3550
- set the trunk and assign vlan to interfaces as you like
3. Ping from VLAN 2 to 3, you should be able to ping.
Plz rate if helpful to you.
Kyaw
