VM running Prime infra 1.2 - continuously rebooting
ldeuren
My VMware virtual machine running Prime Infrastructure 1.2 is continiously rebooting.
VM console is generating logs as shown below.  Has anyone come accross this before? Any thoughts on how to fix this?
Many thanks!
Luc van Deuren
ngoldwat
Level 4
Level 4
Did the install ever work?
Regarding the NMI message:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2031297
Since you have no visibility to the OS, one option is to either restore a VM snapshot, redeploy and restore a backup or
redeploy and reconfigure.  If you had a backup that was not being moved off the
VM server this document may help you get one out of the VMDK file. https://supportforums.cisco.com/docs/DOC-26689
