03-03-2022 11:26 PM - edited 03-03-2022 11:39 PM
Hi everyone,
i'm new to this forum and i'm not an expert with VLAN so be gentle with me [smiley]
We have multiple series 300 / 350 switches with a voice VLAN for our ip phones. So far everything works good.
Recently we added a series 220 switch and this one has slighty different VLAN options which i cannot get right. The phones at this switch don't work properly although i "copied" all the settings from the working switches. Phones that were registered on a working series 300 switch and then connected to the 220 work with minor problems. But i cannot register a new phone at the 220. It gets an IP from the "physical" LAN, not from the VLAN.
All in all i think the 300 has automatics that the 220 does not?
I added some screenshots of the settings, everytime first from a working 300, then from the 220.
Can you please help me?
rznr
LLDP MED Network Policy
LLDP MED Network Policy 300
LLDP Network Policy 220
If the setting "LLDP MED Network Polics for Voice Application" is enabled even the working phones don't work anymore.
Default VLAN Settings
Default VLAN Settings 300
Default VLAN Settings 220
VLAN Settings
VLAN Settings 300
VLAN Settings 220
Port to VLAN
Port to VLAN 300
Port to VLAN 220
Port VLAN Membership
Port VLAN Membership 300
Port VLAN Membership 220
Voice VLAN PropertiesVoice VLAN Properties 300
The setting "Auto Voice VLAN Activvation" is missing on the series 220 switch.
Voice VLAN Properties 220
Auto Voice VLAN
This setting is missing on the series 220 switch
Auto Voice VLAN 300
Solved! Go to Solution.
03-08-2022 05:37 AM - edited 03-08-2022 05:38 AM
We ran some tests and noticed that the switch itself is broken. We replaced it and now everything works fine.
Anyway, thanks for everyones effort.
03-04-2022 12:09 AM
as per your screenshot looks ok high level.
a couple of questions :
1. between SG3XX and SG 2XX switch, there is a trunk config right, did you allow VLAN 254 (or by default trunk allow all VLAN, what config ?)
2. For Testing on SG2XX - on one of the ports just configure only Voice VLAN 254 and check did you get anyIP? or if you manually allocate PC with that IP range are you able to reach Gateway?
Note : You may not get all the features expected to be in SG2XX compare to higher model ( Sg3XX)
If the above setup not working, then you need to disable auto smart port configure voice vlan statically all ports.
On the ports : example :
macro auto disabled
voice vlan id 254
03-04-2022 01:35 AM - edited 03-04-2022 01:42 AM
Hi BB,
regarding your questions:
1) There is a trunk between the switches via Gibics, the 220 ist the last in line. As far as i can see all VLANs are allowed.
2) I tried that but i didn't get any ip.
The 220 does not have a smartport feature. I tried to set up everything manual but then i had to reset the switch because nothing worked anymore...
rznr
03-04-2022 02:01 AM
Not sure if SG220 have SSH access, if yes, please post show run
03-04-2022 12:41 AM
are these Cisco or third party (non-Cisco) phones ? In the latter case, you probably need LLDP enabled, it looks like on the SG300, that is enabled by default. On the SG200 (the second screen shot from above/first one for the SG200) there is a setting:
LLDP MED Network Policy for Voice Application
Try and click the 'Enable' box next to that option.
03-04-2022 01:41 AM - edited 03-04-2022 01:43 AM
Hi Georg,
we use third party phones (Unify Openstage).
If i change the option you mentioned on the 220 the following happens:
rznr
