VoltageSensor OutOfRange
orsonjoon
In DFM we get the following messages:
To start with what is a "VoltageSensor" and where is it for?
Why is the threshold between 1 and 5 and the currant value 0?
How can we get rid of it (I figured the filtering out part allready out myself )
Please can anyone explain this, or is this again another Ciscoworks bug?
8 Replies 8
yjdabear
Looks like there're multiple possible causes:
https://supportforums.cisco.com/message/3182170#3182170
Thanks for the reply, I actually did see that
message before posting mine.
It didn't answer my question though, his problem is different than ours.
Maybe someone knows the real answer to my questions?
This is a known limitation of DFM.  Certain GBIC/XenPak modules do not have a voltage sensor.  In that case, they will report a voltage of 0 (which is fine).  In this case, you can unamange those interface voltage sensors that are not present under DFM > Device Management > Device Details.
Hi Joseph,
I am facing the same voltage OutOfRange problem with two VSS systems using 10GB X2 modules which report voltage as 0. Can you please adapt the above solution to LMS 4.0.1 GUI ? I could not find DFM->Device Management->Device Details in LMS 4.0
Thank you,
Adrian
in LMS 4.1 the Fault Device Details can be accessed here:
Monitor > Fault Settings > Setup > Fault Device Details
Thanks Martin. I did find the location you mentioned but I receive an error when a try to view the details of any device. The error is :
Cannot generate Device Details display.
Please see the DeviceManagement.log  file for more information.
I do not have access to the file at this moment so any suggestions regarding the cause of this error are welcomed.
Adrian
this could be a process failure. Can you post the output of "pdshow" and "pdshow -brief" and when you have access to the log the DeviceManagement.log
Below are the outputs that you requested :
Process               State                                     Pid
  UPMDbEngine           Program started - No mgt msgs received    2236
  UPMDbMonitor          Running normally                          2432
  Tomcat                Program started - No mgt msgs received    808
  TomcatMonitor         Running normally                          4768
  Apache                Program started - No mgt msgs received    4336
  RMEDbEngine           Program started - No mgt msgs received    2124
  Proxy                 Program started - No mgt msgs received    6184
  NameServer            Program started - No mgt msgs received    6192
  NameServiceMonitor    Running normally                          6256
  EDS                   Running normally                          6344
  LicenseServer         Program started - No mgt msgs received    6920
  IpmDbEngine           Program started - No mgt msgs received    676
  INVDbEngine           Program started - No mgt msgs received    1308
  FHPurgeTask           Transient terminated                      0
  FHDbEngine            Program started - No mgt msgs received    1924
  ESS                   Program started - No mgt msgs received    7012
  EssMonitor            Running normally                          7120
  EventFramework        Program started - No mgt msgs received    6324
  PMServer              Running normally                          6472
  SyslogCollector       Running normally                          7060
  EPMDbEngine           Program started - No mgt msgs received    1832
  EPMServer             Running normally                          7008
  FHServer              Running normally                          428
  diskWatcher           Running normally                          5068
  DFMMultiProcLogger    Program started - No mgt msgs received    5044
  DFMLogServer          Program started - No mgt msgs received    5036
  DFMCTMStartup         Administrator has shut down this server   0
  DfmBroker             Program started - No mgt msgs received    6724
  DfmServer             Running normally                          7568
  DfmServer1            Running normally                          7584
  DCRDevicePoll         Never started                             0
  CSSCPServer           Program started - No mgt msgs received    7592
  CSRegistryServer      Running normally                          7600
  CSDiscovery           Never started                             0
  CmfDbEngine           Program started - No mgt msgs received    1580
  CmfDbMonitor          Running normally                          8112
  DCRServer             Running normally                          7240
  CMFOGSServer          Program started - No mgt msgs received    8248
  EssentialsDM          Running normally                          8268
  ConfigMgmtServer      Running normally                          8640
  ConfigUtilityService  Running normally                          8648
  ICServer              Running normally                          8744
  EnergyWise            Running normally                          8972
  PMCOGSServer          Program started - No mgt msgs received    8980
  IPMOGSServer          Program started - No mgt msgs received    8988
  TISServer             Program started - No mgt msgs received    8996
  DFMOGSServer          Program started - No mgt msgs received    9308
  InventoryCollector    Running normally                          9640
  Interactor            Program started - No mgt msgs received    10008
  InventoryCollector1   Program started - No mgt msgs received    10016
  Interactor1           Program started - No mgt msgs received    6804
  NOSServer             Running normally                          6856
  PTMServer             Running normally                          6760
  UPMProcess            Running normally                          9920
  EDS-GCF               Running normally                          9980
  jrm                   Running normally                          6464
  1018                  Never started                             0
  1605                  Never started                             0
  1905                  Never started                             0
  1928                  Never started                             0
  1932                  Never started                             0
  1964                  Never started                             0
  3721                  Never started                             0
  3722                  Never started                             0
  3847                  Never started                             0
  5266                  Never started                             0
  CTMJrmServer          Running normally                          10824
  ChangeAudit           Program started - No mgt msgs received    10032
  SyslogAnalyzer        Running normally                          11024
  DataPurge             Administrator has shut down this server   0
  IPMProcess            Program started - No mgt msgs received    10272
  5341                  Running normally                          2908
  ANIDbEngine           Program started - No mgt msgs received    1540
  ANIServer             Running with busy flag set                11600
  UTMajorAcquisition    Program started - No mgt msgs received    3056
  MACUHIC               Running normally                          11860
  UTLITE                Running normally                          11868
  UTManager             Running normally                          11876
  VNMServer             Program started - No mgt msgs received    11884
  WlseUHIC              Running normally                          11892
  AdapterServer1        Program started - No mgt msgs received    11900
  AdapterServer         Program started - No mgt msgs received    11916
2011|17:27:18.731|ERROR|TIS.KdmCategory|TP-Processor10|DeviceSummaryCollector|authorizeTask|.|Authorization Failure
30-May-2011|18:41:22.410|ERROR|TIS.KdmCategory|TP-Processor2|DeviceSummaryCollector|authorizeTask|.|Authorization Failure
07-Jul-2011|09:12:31.288|ERROR|TIS.KdmCategory|TP-Processor3|KdmSecurity|authorizeTask|.|Authorization Failure
10-Jul-2011|16:33:19.611|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
18-Jul-2011|13:51:59.411|ERROR|TIS.KdmCategory|TP-Processor6|KdmSecurity|authorizeTask|.|Authorization Failure
30-Jul-2011|23:31:11.753|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
02-Aug-2011|13:04:52.077|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
09-Aug-2011|16:44:54.798|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
10-Aug-2011|14:10:40.555|ERROR|TIS.KdmCategory|TP-Processor22|KdmSecurity|authorizeTask|.|Authorization Failure
10-Aug-2011|14:10:58.098|ERROR|TIS.KdmCategory|TP-Processor12|KdmSecurity|authorizeTask|.|Authorization Failure
11-Aug-2011|15:24:02.533|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:16:06.014|ERROR|TIS.KdmCategory|TP-Processor3|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:19:08.346|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:30:10.398|ERROR|TIS.KdmCategory|TP-Processor8|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:33:11.239|ERROR|TIS.KdmCategory|TP-Processor9|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:49:15.310|ERROR|TIS.KdmCategory|TP-Processor9|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:53:16.287|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
18-Aug-2011|14:30:37.604|ERROR|TIS.KdmCategory|TP-Processor14|KdmSecurity|authorizeTask|.|Authorization Failure
18-Aug-2011|14:33:18.055|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
06-Sep-2011|15:01:51.008|ERROR|TIS.KdmCategory|TP-Processor19|KdmSecurity|authorizeTask|.|Authorization Failure
27-Oct-2011|20:56:34.988|ERROR|TIS.KdmCategory|TP-Processor20|KdmSecurity|authorizeTask|.|Authorization Failure
11-Nov-2011|09:36:21.908|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
14-Nov-2011|10:50:42.119|ERROR|TIS.KdmCategory|TP-Processor16|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|14:59:00.309|ERROR|TIS.KdmCategory|TP-Processor11|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:03:51.176|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:04:26.373|ERROR|TIS.KdmCategory|TP-Processor6|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:08:46.310|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:11:30.518|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:40:36.129|ERROR|TIS.KdmCategory|TP-Processor12|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:40:36.148|ERROR|TIS.KdmCategory|TP-Processor12|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:40:36.148|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
    at com.cisco.nm.trx.kdm.utils.DMExportToXML.setSelectedDevices(DMExportToXML.java:40)
    at com.cisco.nm.trx.kdm.actionform.DeviceReportsActionForm.setSelectedDevices(DeviceReportsActionForm.java:56)
    at com.cisco.nm.trx.kdm.action.DeviceReportsAction.perform(DeviceReportsAction.java:322)
    at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
    at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
    at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
    at com.cisco.nm.cmf.util.AjaxAccessFilter.doFilter(AjaxAccessFilter.java:189)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
    at com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
    at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
    at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
    at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:775)
    at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:704)
    at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:897)
    at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
    at java.lang.Thread.run(Thread.java:662)
22-Nov-2011|15:40:36.149|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|15:40:51.034|ERROR|TIS.KdmCategory|TP-Processor12|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|15:43:10.039|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:52:37.637|ERROR|TIS.KdmCategory|TP-Processor5|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:52:37.638|ERROR|TIS.KdmCategory|TP-Processor5|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:52:37.638|ERROR|TIS.KdmCategory|TP-Processor5|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|15:52:37.639|ERROR|TIS.KdmCategory|TP-Processor5|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|16:04:10.184|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|16:10:05.480|ERROR|TIS.KdmCategory|TP-Processor7|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|16:10:05.482|ERROR|TIS.KdmCategory|TP-Processor7|DMException|DMException()|.|Invalid device list
22-Nov-2011|16:10:05.483|ERROR|TIS.KdmCategory|TP-Processor7|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|16:10:05.483|ERROR|TIS.KdmCategory|TP-Processor7|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|19:28:19.977|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
23-Nov-2011|11:43:12.740|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
If you need it I can also post the output of pdshow but it is rather large.
Adrian
