vpn site to site lab
nkhoa4042
Hi All, i have set up a vpn site to site lab. There are 3 sites on my lab. I configurated vpn for DC site and another sites. And how can i set up vpn for the other sites. In order to every site can access to each other. I used IPsec for this vpn site to site lab.
6 Replies 6
Joseph W. Doherty
With the limited information provided, very possibly like how your VPN lab was done.
What you're asking is much like:
Hi All, i have set up a L2 Ethernet site to site lab. There are 3 sites on my lab. I configurated L2 Ethernet for DC site and another sites. And how can i set up L2 Ethernet for the other sites. In order to every site can access to each other. I used fiber for this L2 Ethernet site to site lab.
This is my lab. My problem is the HO-HCM site cannot access to Branch-HCM.
you need some kind of hairpin, in HQ and it long story and not so accurate
instead use DMVPN which can make you connect Spoke-to-Spoke
". . . use DMVPN which can make you connect Spoke-to-Spoke"
That's what I too thought would be the likely approach, but I didn't suggest it as for all we know that's the particular VPN approach already being used in lab (although, if so, don't know what Phase DMVPN being used or supported).
Thanks for your suggestion.
Thanks for your suggestion. I'll try it.
