12-17-2017 01:58 PM - edited 03-01-2019 06:18 PM
hi does anyone know what does evalrighttouse license mean i don't know what it is and i can't find anything about on cisco all i know is when you purchase a license it goes to right to use and if you haven't bought a license it is eval that means you can try it for 60 days but what does the eval right to use mean ?
12-17-2017 02:33 PM
07-01-2020 03:04 AM
@Francesco Molino wrote:
An evaluation licence has a limited life time and at the end of this period, the feature is disabled.
With an evaluation right to use licence, you're in evaluation for 60 days and at the end of the period, the licence is moved in a right to use licence, you'll need to buy this licence but there's no feature disabled after the 60 days. This means that if you forgot to buy your licence during the 60 days, your production isn't impacted but as these licenses are honour based, you'll need to buy them or deactivate them after the 60 days period.
Thanks, this explains well. Is there any published note or URL about this? That would help a lot.
07-01-2020 07:16 PM
