You should be able to pull temps from the C9200 if you SNMP walk the following OID
1.3.6.1.4.1.9.9.91.1.1.1.1.4
The first four values should correspond to the temperature values of the 4 sensors.
Module Sensor MajorThresh MinorThres CurTemp Status
1 FRONT 80 70 30 Ok
1 BACK 70 42 27 Ok
1 CPU 90 80 40 Ok
1 Sugarbowl 100 90 50 Ok
You may also need to adjust the sensor alarm thresholds on your NMS to match with the Cisco defined ones in the switch.
Hopefully this is helpful
