What is the preferred Cisco MIB for C9200L-24P-4G?
ijustworkhere
Having issues with our NMS realizing the temperatures of devices have reached threshold despite the proper temperature value being pulled from the device. Thanks
Ben Walters
Level 3
Level 3
You should be able to pull temps from the C9200 if you SNMP walk the following OID
1.3.6.1.4.1.9.9.91.1.1.1.1.4
The first four values should correspond to the temperature values of the 4 sensors.
Module Sensor MajorThresh MinorThres CurTemp Status
1 FRONT          80                70               30           Ok
1 BACK            70                42               27           Ok
1 CPU              90                80               40           Ok
1 Sugarbowl     100              90               50           Ok
You may also need to adjust the sensor alarm thresholds on your NMS to match with the Cisco defined ones in the switch.
Hopefully this is helpful
