what kind of patch cable from T1 to Pix 515E
timjonke1
What kind of cable should I use between my T1 and my Pix 515E firewall? I have a cat 5e now. Will a cat 6 create more bandwidth?
lgijssel
Level 9
Level 9
You will not be able to connect a T1 directly to a PIX firewall. Although the physical connections might match, it will not work.
You can interconnect the pix and a router terminating the T1, both sides are using ethernet then. (this is probably the situation that you have?) It will make no difference whether you use cat5 or cat6 for this link.
Leo
