When i disable PC firewall then Vlan to Vlan ping work, otherwise doesn't get reply
JI-RAJU
I have one SG350-28 Manageable L3 and one is old Linksys SRW224G4 L2 Switch. So i configured 2 VLANs on L2 switch and assign the port fa0/2 as acces port and also define access vlan 2 for Vlan 2 and same for Vlan 3 on fa0/3 and G1 as trunk port and also encapsulation dot1q not showing in L3 Sw.
L2 SW- vlan 2(fa0/2) and 3 (fa0/3) and trunk (G1)
L3- Put ip on interface vlan 2- 162.16.2.1 255.255.255.0 and Vlan 3- 162.16.3.1 255.255.255.0
      PC 0 IP- 162.16.2.2 and PC1 IP- 162.16.3.2
      Trunk on L3- on int Gi1
The problem is when i ping from the L3 sw to Both pc thn ping reply but whn i ping pc0 to pc1 thn nothing reply whn i disable pc firewall on both pc the it's ok.
I'm new in this community so anything wrong thn please consider :D
balaji.bandi
as per your description, you need to add FW rule to allow Ping. (test and advise)
https://www.howtogeek.com/howto/windows-vista/allow-pings-icmp-echo-request-through-your-windows-vista-firewall/
BB
balaji.bandi
BB
Thanks to you for rapid reply but in my office we have 700 PC , so if i do it manually. It's so.... . So there any option in L3 switch to accept this ICMP Echo Reqest and another question was switchport trunk encapsulation dot1q doesn't show in L3 Switch . So anything .....Plz
if you have centralise SCCM, should take care of it.
BB
