mhiyoshi
Beginner
Why Cat95K Normal mode and Cat93K must configure FNF counter long keyword?
Dear all,
Currently I have been investigating the following limitation for example,
Cat95K High Performance Model can configure FNF counter bytes/packets without long option but
Cat95K Normal and Cat93K do not support itself and long option is mandatory however there is not
any related information so I appreciate if you can let me know any information.
[Condition]
IOS-XE-Ver.16.9.3
License : NW-Advantage, DNA-Advantage
[Verification]
Cat95K-HIGH(config)#flow record RECORD
Cat95K-HIGH(config-flow-record)#collect counter bytes ?
layer2 Total number of layer 2 bytes
long Total number of bytes (64 bit counter)
<cr> <cr>
Cat95K-HIGH(config-flow-record)#collect counter packets ?
long Total number of packets (64 bit counter)
<cr> <cr>
Cat95K-NORMAL(config)#flow record RECORD
Cat95K-NORMAL(config-flow-record)#collect counter bytes ?
Cat95K-NORMAL(config-flow-record)#collect counter packets ?
*Cat93K is also same output.
The followings are each Release Note and FNF configuration guide.
[Release Note - Cat9500/9300]
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/release_notes/ol-16-9-9500.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/release_notes/ol-16-9-9300.html
Limitations and Restrictions
Flexible NetFlow limitations:
You can not configure NetFlow export using the Ethernet Management port (GigabitEthernet0/0).
You can not configure a flow monitor on logical interfaces, such as switched virtual interfaces (SVIs), port-channel, loopback, tunnels.
You can not configure multiple flow monitors of same type (ipv4, ipv6 or datalink) on the same interface for same direction.
[FNF Configuration Guide - Cat9500/9300]
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-6/configuration_guide/nmgmt/b_166_nmgmt_9500_cg/b_166_nmgmt_9500_cg_chapter_0111.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/nmgmt/b_169_nmgmt_9300_cg/configuring_flexible_netflow.html
Best Regards,
Masanobu Hiyoshi
0 REPLIES 0
