I need to know more about the steps and process that RME takes when you run a simple compliancy check. I ran a check against 600 content engines that only checked for NTP statements and it took about 48 hours. At another time, I checked 60 some CATOS switches that took over 36 hours? It doesn't seem to make a difference if you just run a compliancy check or a compliancy & deploy, or just a deploy job. They all take far too long.
In one case, we checked for snmp statements on CATOS switches and the first 15 devices or so only took about 4 minutes. Then it sat there forever and finally finished about 36 hours later.
Are the devices being checked sequentially instead of in parallel?
Finally, is there an improvement to this in LMS 3.x? We are running LMS 2.6 with all the latest service packs and IDU's.
