03-11-2022 04:13 AM - edited 03-11-2022 04:13 AM
My two phones don't get IP addresses from DHCP Vlan 66, could you tell me why ? The GUI of the IP phones print "Configuring IP".
Router>Router>en
Router#sh run
Building configuration...
Current configuration : 1269 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp excluded-address 10.66.0.1
ip dhcp pool voix
network 10.66.0.0 255.255.0.0
default-router 10.66.0.1
option 150 ip 10.66.0.1
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017SHJS-
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.66
encapsulation dot1Q 66
ip address 10.66.0.1 255.255.0.0
interface FastEthernet0/0.99
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
telephony-service
max-ephones 5
max-dn 5
ip source-address 10.66.0.0 port 2000
auto assign 4 to 6
auto assign 1 to 5
ephone-dn 1
number 101
ephone-dn 2
number 102
ephone 1
device-security-mode none
mac-address 0030.A398.B802
type 7960
button 1:1
ephone 2
mac-address 0030.A398.B803
type 7960
button 1:2
line con 0
line aux 0
line vty 0 4
login
end
SWitch
hostname Switch
lldp run
switchport access vlan 66
switchport trunk native vlan 99
switchport mode trunk
switchport voice vlan 66
interface FastEthernet0/2
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan66
ip address 10.66.0.2 255.255.0.0
interface Vlan99
ip address 192.168.99.10 255.255.255.0
ip default-gateway 192.168.99.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
Thank you for your help
Mike
Solved! Go to Solution.
03-11-2022 11:30 AM
in short, everything was misconfigured: the access ports, the trunk port, the subinterface on the router, the switch SVI, and the ephone mac addresses. I have revised the file, review the configurations...
03-13-2022 10:01 AM
good stuff ! I did not list all errors in detail, but I guess you figured it out anyway !
03-11-2022 09:24 AM
Is it PacketTracer? can you add the pkt file in here?
03-11-2022 09:40 AM
there is one crucial mistake in your configuration, change that and check if it works then:
--> --> ip source-address 10.66.0.0 port 2000
needs to be:
--> --> ip source-address 10.66.0.1 port 2000
03-11-2022 10:29 AM - edited 03-11-2022 10:29 AM
03-11-2022 11:30 AM
03-13-2022 09:26 AM
Thank you ! I checked your config and tried to do it myself and now... it works ! @Georg Pauwen
03-13-2022 09:26 AM
03-13-2022 10:01 AM
