04-20-2021 07:55 AM - edited 07-05-2021 01:11 PM
Hello Experts @balaji.bandi @Marvin Rhoads @Rob @Richard @georg
I am looking to add Cisco Catalyst 9120 APs to 3 different sites and got few questions?
Does Cisco Provide any cloud management for Wireless APs which eliminate the need of physical controller?
In case Physical Controller is only choice, Do i need one for each site ? or it will be one fine for all sites (Considering all sites are connected by IPSec)?
How does licensing work with it ? Is it just one time buy and then annual support ?
Lovejit Singh
04-20-2021 09:03 AM
You can use virtual controller in terms of Cisco AP concern :
https://www.cisco.com/c/en/us/products/wireless/virtual-wireless-controller/index.html
If you looking managed device using cloud then look at Meraki.
04-22-2021 05:53 AM
I'd suggest new 9800 series not AireOS virtual WLC!
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html
04-20-2021 03:58 PM
04-22-2021 05:54 AM
ME - not for 9120!
For 9120 you want Embedded Wireless Controller with Catalyst Access Points https://www.cisco.com/c/en/us/products/wireless/embedded-wireless-controller-on-catalyst-access-points/index.html but that is *not* a cloud management option.
