Wildcard in a netconfig job?
jpazahanick
Level 4
Level 4
I was wondering if there was a way to specify a wildcard in a Netconfig job...
For example, here is a snip of the current config;
interface GigabitEthernet1/0/0.12300074
encapsulation dot1Q 1230 second-dot1q 74
ip unnumbered Loopback1200
ip helper-address 172.30.31.3
ip helper-address 172.30.31.4
no cdp enable
service-policy type control DHCP-NAS
ip subscriber l2-connected
initiator dhcp class-aware
interface GigabitEthernet1/0/0.12300075
encapsulation dot1Q 1230 second-dot1q 75
no cdp enable
interface GigabitEthernet1/0/0.12300076
encapsulation dot1Q 1230 second-dot1q 76
no cdp enable
There are close to 4000 subinterfaces like these.. I would like to be able to create a job to say remove the ip helper addresses of all 4000 subinterfaces. Is this possible?
Marvin Rhoads
Netconfig jobs should accept the asterisk (*) as a wildcard.
I recommend you take a look at the "Features of Baseline Templates" section of the RME User Guide for some further pointers on using wildcards to check and enforce template compliance - the task you seem to be investigating.
