11-05-2012 08:03 PM
I am deploying 4g hwics for remote locations. The 4g hwics work well most of the time. However I am seeing one issue that i'm hoping can be addressed using a script. We have 4g hwics that connect to the LTE netwwork. However at times it drops to the 1xrtt network. Which i expect from time to time. But what i am noticing is that the hwic doesn't always go back to the LTE network unless the radio or the router is reloaded. So what I would like to do is have a script that checks the status of the radio. If the hwic is connected to the LTE network then drops to to the 1xrtt network. I'd like the script to shutdown the radio and turn back on. Hopefully to try to reconnect to the LTE network.
regards
Stewart
11-11-2012 08:27 AM
What are the steps to do this manually? That is, how does one know the radio has dropped to the 1xrtt network? How does one know it's on the LTE network?
11-12-2012 01:50 PM
so to see the wireless network you are on from the router cli. the only way to tell when it drops from the LTE network is to run the command below.
you type
sho %WirelessCardSlot#% radio
show cell 0/0/0 radio
normall it wouls look like when it is on the LTE network.
Radio power mode = ON
Current RSSI = -75 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE <----- will tell you that your on the LTE network.
What it looks like when it drops off the LTE network.
1xRTT related info
Current RSSI = -0 dBm
HDR (1xEVDO) related info
Current RSSI = -117 dBm
LTE Technology Selected = eHRPD <--- on it's on the non evdo network.
11-12-2012 03:16 PM
Okay. I think this applet should do what you want:
event manager applet watch-lte
event timer watchdog time 60
action 001 cli command "enable"
action 002 cli command "show cell0/0/0 radio"
action 003 regexp "LTE Technology Selected = (LTE|eHRPD)" $_cli_result match tech
action 004 if $_regexp_result eq 1
action 005 if $tech eq "LTE"
action 006 context save key LTECTXT variable tech
action 007 exit 0
action 008 end
action 009 else
action 010 set currtech $tech
action 011 context retrieve key LTECTXT variable tech
action 012 if $tech ne $currtech
action 013 cli command "config t"
action 014 cli command "interface cell0/0/0"
action 015 cli command "shut"
action 016 cli command "no shut"
action 017 cli command "end"
action 018 end
action 019 set tech $currtech
action 020 context save key LTECTXT variable tech
action 021 end
06-02-2013 08:39 AM
i want to use an applet like this but for 819 dual sim router which supports only 3g and 2g (wcdma and gsm )
so when signal goes from wcdma to gsm in the activated sim it switchs to the other (sim) and test if its signal is wcdma so it can be used instead of the gsm one !
please help me write such an applet
06-02-2013 08:46 AM
Please start a new thread for your issue, and include the steps/output one would use to verify the conditions you require manually.
03-11-2013 11:27 AM
Have you tried the following?
router#cellular 0/0/0 lte technology lte
I haven't tried this myself, but I'm running into a similar problem, except I have less visibility and currently my only way into the router is over the LTE connection. Thankfully it's temporary.
Joseph Clarke: thanks for a great example of regex use in event manager. I keep discovering new things I didn't know EEM could do.
