Good day,
On CWLMS Prime, currently you can not manage AP's as stated below:
How is a device defined within CiscoWorks device counts?
A. A device is defined as a unique IP Address and System Object ID (SysOid). A single chassis will be counted as multiple devices if the chassis is configured with multiple IP Addresses. Ex. A switch with multiple line cards, NAM, firewall etc. or a stackable switch that has an IPAddr assigned to each switch that participates in the stack will be treated as multiple devices within CiscoWorks. Note:IP Phones and controller based access points do not count as managed devices within LMS.
Will there be a new release that will eventually allow management of these AP's
