Wireshark capture VLAN IDs
berniebbow1
I need to capture switchport's packets and see if a correct VLAN is set.
Capture packets don't have VLAN IDs - whole header is missing.
Workstation is Windows 10 with latest Intel driver and the driver has working VLAN support.
Also tried ASUS USB ethernet adapter with VLAN support with no success.
I initiate communication with a device (to access web conf GUI), which is plugged in gi1/0/1.
The device is wireless AP, where VLAN 20 is management and VLAN 10 is data.
The Device does not support wireless VLAN tagging and therefore VLAN 20 is tagged and VLAN 10 untagged.
Catalyst 3750:
interface gigabitethernet 1/0/1
 switchport mode trunk
 switchport encapsulation dot1q
 switchport trunk native vlan 10
 switchport trunk alloved vlan 10,20
interface gigabitethernet 1/0/2
monitor session 1 source interface gi1/0/1 both
monitor session 1 destination interface gi1/0/2 encapsulation replicate
marce1000
 - As far as I understand the info from the link below you may need to change registry settings on windows too :
 https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005498.html
M.
berniebbow1
Nobody?
marce1000
M.
