WLC 2504 in Cisco Prime Infrastructure 1.2
Dejan Rotula
Trying to add Cisco 2504 Wireless Controller, Software Version 7.3.101.0, to Cisco Prime Infrastructure
1.2 (1.2.0.103), License Evaluation, with no success.
When using Discovery, Discovery Job show Credential Errors: "Error occured due to invalid SNMP credential"
When Add Device from Device Work Center I get:
Reachability is "Unknown", Device Type is empty, Collection Status is "Managed with Warnings", with message "SNMP Failure: No Response for SNMP Get request.", Collection Time is empty.
I've tried with both snmp v2 and v3.
I've tried to lower "Maximum VarBinds per Get PDU" to 10 or 20, cause I've read similar problem in NCS.
I solved the same problem 5min ago.!
select the device and press syc ..that helped me ...
