04-04-2011 02:01 AM
Hello.
I am trying to include a WLC 5508 in our LMS 3.2.
I have defined the device and credentials, but the LMS server cannot get access to it.
If I try to check de device credentials from the Device Center I get a "failed to connect", but if I a try a telnet session, also from Device Center, I get a connection.
I checked the credentails are OK.
Thank you.
04-04-2011 03:21 AM
You need to download and install the last package : WLC.RME431.v2-1.zip : http://www.cisco.com/cisco/software/cart.html?imageGuId=E3A42793DA29A1B6AC3024C088F9FBC2B324EC8B&i=rs
You must install : MDF 1.37
You must install packages before WLC.RME431.v2-1.zip:
SharedSwimWLC.RME431.v1-2.zip
SharedDcmaWLC.RME431.v1-1.zip
SharedSwimIOS.RME431.v2-5-4.zip
LibSwim.RME431.v2-5-3.zip
LibCommon.RME431.v2-4-2.zip
Elisabeth
WLC.RME431.v2-1.readme:
Supported Devices
Device Type : Cisco 5500 Series Wireless LAN Controllers
Cisco 3750 Switch with Wireless LAN Controller
Devices/Modules Supported :
Cisco 5508 Wireless LAN Controller : 1.3.6.1.4.1.9.1.1069
Cisco 3750 24+2 port 10/100/1000 Switch with integrated Cisco 4402 Wireless Controller: 1.3.6.1.4.1.9.1.747
Features Supported:
Inventory Manager : Yes
Syslog Analyzer : Yes
Config.Mgmt : Yes
Software Mgmt : Yes
Minimum Software : 6.0.188.0
Hardware and Software Requirements
Hardware and software requirements are the same as those needed for Resource Manager
Essentials 4.3.1 installation.
You must install Resource Manager Essentials 4.3.1 and MDF 1.37 before installing the
device package.
For a detailed list of requirements, as well as instructions for installing Resource
Manager Essentials 4.3.1, go to Cisco.com.
For documentation on Resource Manager Essentials, see:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/tsd_products_support_series_home.html
Package Dependencies
To install the WLC Package, you must install the
following dependent packages:
04-04-2011 03:24 AM
Thanks a lot.
Fernando.
