06-19-2007 07:43 AM
I have wireless and use the WLSE to manage the AP's. The question I have is when I move an AP will the WLSE update automatically or do I have to make the change manual. If it is manual how do I make the change. Thanks
06-25-2007 10:14 AM
The method for an upgrade to WLSE 1.3.x:
Downloads the ISO recovery CD images
Reassemble and burn them onto a CD
Uses the recovery CD to upgrade
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_tech_note09186a008016970b.shtml#um
06-27-2007 06:41 AM
I believe you will have to move them manually, just like you had to place them manually in location manager during the initial setup.
