06-27-2007 01:11 PM
Has anyone gotten WLSE to authenticate to APs using Telnet via RSA's ACE? We're being told it doesn't work, but neither Cisco or RSA can explain why.
I can manually log into a test AP pointing to an ACE server using a static account/password. But if I configure those credentials in WLSE in the "Telnet/SSH" section and try the connectivity there, it doesn't work.
07-03-2007 07:42 PM
The only thing I know is that WLSE has to store a static password to connect to the AP's.
WLSE still doesn't support ACE or random generated tokens and needs a fixed password.
It might be worth your while speaking to your account team about creating an enhancement request to try and get this feature added to WLSE.
07-05-2007 07:09 AM
Thanks for your reply, but you'll notice I mentioned "static" username/password. We're not trying to authenticate using a random token-password.
