Highlighted
Beginner
WS-C3650-48PS management with CNA 6.3
Hi community,
I have a new switch WS-C3650-48PS installed and it holds our VTP domain. I tested to active a suspended VLAN via CNA 6.3 and no error return after the apply button. I press the refresh button again and I found the new setting was not apply to the switch.  I also got the error on the port setting page insides CNA 6.3 . I did not have the same problem on the same CNA on my other Cisco switch.
Is that CNA 6.3 not supporting my new switch ?
ERic
1 REPLY 1
Highlighted
Participant
Hello Eric,
With Cisco Network Assistant 6.1.0 you will be able to manage the switch WS-C3650-48PS.
You can check the release notes for the same.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_network_assistant/version6/relnotes/ol32368.html
Content for Community-Ad
