WS-SVC-NAM-1 unsuccessful upgrade. Recovery.
Joe Mack
I have a problem with WS-SVC-NAM-1 Module. Can anyone advice how to recover after unsuccessful upgrade?
I successfully upgraded Application Image from 3.4 to 4.2 step by step:
3.4 --> 4.0
4.0 --> 4.1
4.1 --> 4.2
Next step was upgrading from 4.2 to 5.0 version and at this point installation failed:
Maintenance image version: 2.1(2)
Do you want to proceed installing it [y|N]: y
Proceeding with upgrade. Please do not interrupt.
If the upgrade is interrupted or fails, boot into
Maintenance image again and restart upgrade.
Creating NAM application image file...
Executing pre install actions...
/bin/mkdir: cannot create directory `/mnt/hd/nvram': Read-only file system
Initializing the application image partition.
This process may take several minutes...
Applying the image, this process may take several minutes...
Failed to apply the NAM image. Exiting...
ERROR: Application installation has failed. View the upgrade log for details.
After this step Module was accidentally reseted to Application, not to Maintenance Image.
(by command hw-module switch 1 module 6 reset hdd:1)
Now when module starts to boot, nothing happens. After 5 minutes of booting switch powers down slot.
Last transition recorded: (timer)-> check_power_on (power_on_ok)-> wait_til_online (disabled)-> disabled (disabled)-> disabled2 (disabled)->
stay_disabled (operator_power_on)-> can_power_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)-> check_power_on (power_on_ok)-> wait_til_online
%C6KPWR-SW1_SP-4-DISABLED: power to module in slot 6 set off (Module  Failed SCP dnld)
switch#show mod
Mod Ports Card Type                              Model              Serial No.
  8    3  Network Analysis Module                WS-SVC-NAM-1       SAD123406UV
Mod MAC addresses                       Hw    Fw           Sw           Status
  8  0017.95a3.4840 to 0017.95a3.4847   4.0   7.2(1)       20.1(1)SXJ2  PwrDown
Mod  Online Diag Status
  8  Not Applicable
During boot hw-module reset can not be used, because module is in Unknown state.
Also during boot "session switch 1 slot 8 processor 1" card is unreachable
Is now both Maintenance and Application Images corrupted?
How to proceed with recovery?
AFROJ AHMAD
Hi ,
try the below step:
-       Login to the Switch
-       Ran the command :
-       hw-module module 8 reset   ( do  show mod and check the status of the NAM module )
-       if above did not work and you found  ( power down or other ) in the show mod for NAM module , then ran the below command
-       power enable module 8
-       Now wait for 5-10 mins and check the status of the NAM module
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
