cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
WS-X45-SUP7-E, Standby Supervisor, SSO, Disabled
vegatank-jsh
Q >
SSO Standby cold.... andthen Redundancy Mode Disabled....
Why does not the recognized supervisor?
Without reload the switch, any way to recognize the supervisor?
Step 1> different versions of IOS
htw_Legacy_BB_#2#
*Dec 26 11:38:31: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X45-SUP7-E S/N: CAT1508L0PQ Hw: 1.0) is online
*Dec 26 11:38:31: %C4K_REDUNDANCY-2-IOS_VERSION_CHECK_FAIL: IOS version mismatch. Active supervisor version is 15.1(2)SG3 (cat4500e-UNIVERSALK9-M). Standby supervisor version is 15.0(1)XO (cat4500e-UNIVERSALK9-M). Redundancy feature may not work as expected.
*Dec 26 11:38:31: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for rpr mode
*Dec 26 11:38:32: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
*Dec 26 11:38:37: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
*Dec 26 11:38:37: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
*Dec 26 11:38:37: %C4K_REDUNDANCY-5-CALENDAR: The calendar has been successfully synchronized to the standby supervisor for the first time
*Dec 26 11:38:37: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
*Dec 26 11:38:37: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Dec 26 11:38:39: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
*Dec 26 11:38:39: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (RPR)
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#sh module
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT1746L1PB
2 24 1000BaseX (SFP) WS-X4624-SFP-E JAE162903UO
3 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1710L0T6
4 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1508L0PQ
M MAC addresses Hw Fw Sw Status
1 24e9.b3f4.a378 to 24e9.b3f4.a3a7 1.1 Ok
2 b0fa.ebc6.2438 to b0fa.ebc6.244f 1.2 Ok
3 4c4e.3581.27c0 to 4c4e.3581.27c3 2.1 15.0(1r)SG5 03.04.03.SG Ok
4 4c4e.3581.27c4 to 4c4e.3581.27c7 1.0 15.0(1r)SG11 03.01.00.SG Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor RPR Active
4 Standby Supervisor RPR Standby cold
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#show redundancy states
my state = 13 -ACTIVE
peer state = 4 -STANDBY COLD
Mode = Duplex
Unit = Primary
Unit ID = 3
Redundancy Mode (Operational) = RPR
Redundancy Mode (Configured) = Stateful Switchover
Redundancy State = RPR
Manual Swact = enabled
Communications = Up
client count = 76
client_notification_TMR = 240000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#sh redundancy
Redundant System Information :
Available system uptime = 4 hours, 53 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = RPR
Reason: Unknown
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 3
Current Software state = ACTIVE
Uptime in current state = 4 hours, 51 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.03.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 14:08 by prod
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 4
Current Software state = STANDBY COLD
Uptime in current state = 5 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.01.00.SG RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 10-Sep-10 04:08 by pro
htw_Legacy_BB_#2#
Step 2> IOS file copy from Active Sup to Standby Sup
htw_Legacy_BB_#2#copy slot0:ca
htw_Legacy_BB_#2#$cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin sla
htw_Legacy_BB_#2#$niversalk9.SPA.03.04.03.SG.151-2.SG3.bin slavebootfl
htw_Legacy_BB_#2#$niversalk9.SPA.03.04.03.SG.151-2.SG3.bin slavebootflash: ?
<cr>
Destination filename [cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
<obmit>
125611132 bytes copied in 421.808 secs (297792 bytes/sec)
htw_Legacy_BB_#2#
htw_Legacy_BB_#2(config)#boot system flash:?
WORD
htw_Legacy_BB_#2(config)#$4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin ?
<cr>
htw_Legacy_BB_#2(config)#exit
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#sh bootvar
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby BOOT variable =
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#d
htw_Legacy_BB_#2#wr
Building configuration...
Compressed configuration from 11905 bytes to 4495 bytes[OK]
*Dec 26 12:00:48: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
*Dec 26 12:00:49: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Dec 26 12:00:49: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
htw_Legacy_BB_#2#
htw_Legacy_BB_#2#
BOOT variable = flash:cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin,12;
Standby BOOT variable = flash:cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin,12;
htw_Legacy_BB_#2#
Step 3 > Stanbdy Sup reset...
htw_Legacy_BB_#2#hw-module module 4 reset
Proceed with module reset? [confirm]
htw_Legacy_BB_#2#
*Dec 26 12:05:00: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been lost
*Dec 26 12:05:00: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has been lost
Rommon (G) Signature verification PASSED
Rommon (P) Signature verification PASSED
htw_Legacy_BB_#2#
4 Supervisor
4 Unknown Unknown Unknown Other
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Disabled
htw_Legacy_BB_#2#
Best Regards
3 RESPUESTAS 3
Marvin Rhoads
Well your last output indicates the hardware module in slot 4 is not recognized. That will certainly prevent it from operating as a hot standby.
The command once it had the IOS upgrade completed should have been "redundancy reload peer". Reference.
casanavep
Level 3
Level 3
Also, notice your output "BOOT variable =" shows no boot order.  Was this the only file in bootflash.  If not, it likely booted to the "first" image found.  Also, it appears your secondary supervisor had not finished booting or failed to boot after you reset it.  To echo what Marvin said, your initial problems with not going to a hot standby were because you were on two different major IOS releases, 15.0 on one and 15.1 on the other  (IOS XE 3.01 on one and 3.04 on the other).  You can be on different patches of the same major release, but not on different major releases or capabilities, i.e. IP Base on one and Adv Enterprise on the other (pre-Universal image issue). What do you show from a console connection of the standby Sup, is it booted to IOS and the right IOS?
There is crash info file been generated on the device if in case you get that would be helpfull.
your switch had crashed with the following errors present in the crash log:
8/000044: Apr 25 16:37:12.824 GMT-5: %SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, chunk 88A0AC70  data 88A130A8  chunkmagic 5DA3C78B  chunk_freemagic 0 -Process= "Check heaps", ipl= 0, pid= 7
-Traceback= 1#d1c16a2e6f8ceec1892aa2e47e2a2618  :10000000+FCC0E4 :10000000+1BEE4E4 :10000000+1BEE794 :10000000+1C168F00
This is a memory corruption issue. Within IOS, each chunk of memory has
a "header" followed by the data itself. The header describes various
attributes about the data, including what type of data is held within
the chunk. Any chunks of memory that are freed are given what is known
as a "CHUNKFREEMAGIC" code within the header. In your case, we have
determined that this field had been corrupted, varying only a few bits
from the expected value.
After contacting internal groups that support the Supervisor 7E, I have
been referred to bug CSCtr35883, which is a similar sort of memory
corruption on your version of IOS, identical except for the fact that
the individual who originally hit the bug had seen corruption in a
different field. from your crash logs, it appears that you are definitely running
into this defect. Apparently, several bits are being written into the
corrupt chunk of memory from the previous chunk that comes just before
it, a phenomenon known as "overflow."
