04-24-2005 10:42 PM - edited 03-10-2019 01:25 AM
I've got 7206 IP/FW/IDS 12.3(11)T3
The very strange problem:
1) half of SMTP trafic does not flow from Internet to my inside SMTP server (public address) Though I turned all signatures off except HTTP block
2) inside FTP clients can not get some files from some Internet FTP-servers Though I turned all signatures off except HTTP block
If I turn IPS off then no problems happen
Configuration:
ip ips po max-events 10000
ip ips signature 3103 0 disable
ip ips signature 3151 0 disable
ip ips signature 3100 0 disable
ip ips signature 4052 1 disable
ip ips signature 4052 2 disable
ip ips signature 4600 0 disable
ip ips name fromWAN
interface GigabitEthernet0/2
ip ips fromWAN in
I want to control IDS behaviour but can't
04-27-2005 05:20 PM
do you see any IPS signature alerts ?
You can configure and provision IOS IPS using SDM.
04-27-2005 06:14 PM
As for syslog - NO
When I disable signaatures they stop to flow to my syslog
Well, what about CLI? Is it mandatory using SDM?
I don't have SDM now, of course it is possible download and install but if only there is no CLI-way.
04-28-2005 12:20 PM
IOS IPS allows loading new signatures dynamically. Depending on the platform, the number of signatures on the device might be as high as several hundred signatures. Managing them all at CLI could be a nightmare.
SDM would allow you to manage them more easily.
Having said that, IOS IPS does offer a limited CLI
that allows you disable, delete or attach an ACL to
a signature - currently. And further CLI enhancements
are being scoped.
