11-22-2015 09:58 AM - edited 03-11-2019 11:55 PM
Dear All,
Kindly suggest (A)
I configured Active (ASA1) and Standby(ASA2) failover, both are working fine .
Q.....When I shut the ASA1 and when it will come in ok position must be active. Kindly suggest ,is it posible or not .if yes, suggest commnad by which it can change it's state .
Kindly suggest (B)
I configured Active/Active (ASA1)and standby/standby(ASA2) Failover, both are working fine ,Now i want to make it as Active/Standby (ASA1) and Active/Standby (ASA2) ..Means i want change context either in active or standby according to requirmet .
Arshad Ayub
Solved! Go to Solution.
11-23-2015 04:29 AM
Hi Arshad,
1: On ASA the Active device continues to be in Active state unless you manually trigger failover or the conditions for failover are met in the network. In other words there is no preemtion in terms of active firewall.
2: Your second requirement seems to be Active/Active configuration of ASA. This supported in multicontext mode. In this mode you can create groups of context and choose individual units to have either or all groups in active state.
Refer following link for more details about failover:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa91/configuration/general/asa_91_general_config/ha_failover.html
Rishabh Seth
PS: Rate if it helps and mark answer as correct if it resolves your issue.
11-23-2015 04:29 AM
Hi Arshad,
Rishabh Seth
11-23-2015 10:25 AM
Hi Rishabh,
well supported for me
Arshad Ayub
