ASA 5505 - Setting up 2 LAN Networks and 2 WAN connections
integservices
I have an ASA 5505 with Security Bundle license.
I am able to create 2 LAN networks (192.168.9.0 and 172.16.9.0) Vlan1 and Vlan12 respectively. I also setup 2 outside interfaces (outside1 and outside2).
Network 1 (192.168.9.0 - VLAN1) has no issues going out via Outside1, however I can't get Network 2 (172.16.9.0 - VLAN 12) to go thru outside2.
I put in a static route (route outside 172.16.9.0 255.255.255.0 x.x.x.x), the x.x.x.x is the default gateway of my ISP.
Does anyone know how i can accomplish this?
RICH
7 Replies 7
Eddy Duran
Hello Rich,
Could you paste your configuration? The route statement that you entered is telling the ASA to send traffic for the 172 subnet using the outside 2 but the traffic coming from that new interface would still use the default gateway for the traffic going to internet, I assume that the default gateway on your asa is pointing to the outside 1
Hope this works for you.
That is probably what i am missing. how do i let the new interface go to the other gateway?
Here is my config.
ASA Version 8.2(5)
hostname JC-CHATHAM
enable password .PlakDGVFWS.y/j9 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 22
interface Ethernet0/5
switchport access vlan 12
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside1
security-level 100
ip address 192.168.9.1 255.255.255.0
interface Vlan2
backup interface Vlan22
nameif outside1
security-level 0
ip address 108.35.180.120 255.255.255.0
interface Vlan12
nameif inside2
security-level 100
ip address 172.16.9.1 255.255.255.0
interface Vlan22
nameif outside2
security-level 0
ip address 173.70.17.250 255.255.255.0
ftp mode passive
pager lines 24
logging asdm informational
mtu inside1 1500
mtu outside1 1500
mtu inside2 1500
mtu outside2 150
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside1) 1 interface
nat (inside1) 1 0.0.0.0 0.0.0.0
route outside1 0.0.0.0 0.0.0.0 108.35.180.1 1
route outside2 0.0.0.0 0.0.0.0 173.70.17.1 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 108.179.13.0 255.255.255.0 outside1
http 192.168.9.0 255.255.255.0 inside1
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside1
dhcpd address 192.168.9.100-192.168.9.200 inside1
dhcpd dns 68.237.161.12 8.8.8.8 interface inside1
dhcpd enable inside1
dhcpd address 172.16.9.100-172.16.9.150 inside2
dhcpd dns 8.8.8.8 interface inside2
dhcpd enable inside2
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:9d0ae3f2211bdfec4c6228dd78d854c2
i also changed
to
route outside1 192.168.9.0 255.255.255.0 108.35.180.1 1
route outside2 176.16.9.0 255.255.255.0 173.70.17.1 2
and it didn't work
Any help is appreciated. Thanks
To your initial config , try by adding nat/global for 2nd subnet. Also, I would change 1subnet nat statement to specific subnet.
Modify:
nat (inside1) 1 0.0.0.0 0.0.0.0  --> nat (inside1) 1 192.168.9.0 255.255.255.0
add:
global (outside2) 2 interface
nat (inside2) 2 176.16.9.0 255.255.255.0
See if this works.
hth
MS
I think this helped a bit but I still have issues on getting to the internet via outside2.
But this is what i noticed.
if i swap the metric on the following:
making it route outside1 0.0.0.0 0.0.0.0 108.35.180.1 2 and route outside2 0.0.0.0 0.0.0.0 173.70.17.1 1
I can now get out from inside2 to outside2 but cannot get out from inside1 to outside1
How can i make the default gateway different for the 2 interfaces?
Hey Richard,
Unfortunately there is no way to specify a different gateway for those 2 interfaces. The ASA would always do a route lookup and will match the route statement with the lowest administrative distance.
Let me know if you have any doubt or question.
Hi Richard,
What Eddy mention was correct. Somehow I misread you initial posting. You can use two default routed with same metric as long as they are on same outside interface but not 2 diff subnets thru two diff outside interface. The second internet can be used as backup with ipsla config. Check below link..
http://www.cisco.com/en/US/partner/docs/security/asa/asa72/configuration/guide/ip.html
hth
MS
