ASA 5510 7.2 two isp problem (not backup or load balancing)
tiago.nunes
Hi there
I'm having a problem with an ASA. I have the scenario that is shown in the word document attached. The problem is that, when i create the static route in the ASA, the traffic to the vpn is not forwared to the correct interface. Instead, is forwarded to the default route. the tunnel is well established, but the traffic is not going trough the correct interface. When i point the default route to the adsl 1 interface, everything works fine...but not as the costumer wants
I send the configuration of the ASA. In the configuration is not shown the correct routes, because i had to remove them to leave everything working trough ADSL1.
But they would be something like this
route outside 10.2.20.0/24 10.0.10.254
route outside 2 0.0.0.0/0 10.0.11.254
Thanks in advance
Best regards
thefindjack
Try this....
route outside 0.0.0.0 0.0.0.0 10.0.10.254 1 tunneled
route outside2 0.0.0.0 0.0.0.0 10.0.11.254 1
Here is a document that explains this.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps6659/prod_white_paper0900aecd805f0bd6.html
Please rate if this helps!
Just like that? In the document the refer policy routing. I won't need to do that?
Not for ASA/PIX, this is a built in feature that allows all traffic that came into the device encrypted to leave out of the "tunneled" default route and all traffic that comes in unencrypted leave via the normal default route.
Thank you very much for your help! I'll try that tomorrow. I'll post again and rate your help as soon as i try it
