ASA 5510 8.4.6 Outside interface NAT issue
epasqualotto
Hi all, I've just upgraded my ASA 5510 to 8.4.x and I can't NAT on outside interface anymore.
I can't understand when Packet-tracer say me "implicit rule".
This is an example of my config:
object network Zabbix
nat (Lan,Esterna) static interface service tcp www 8080
(maybe one is ok but I tried both ports)
access-list Esterna_access_in extended permit tcp any object Zabbix eq www
access-list Esterna_access_in extended permit tcp any object Zabbix eq 8080
nat (Lan,Esterna) source dynamic Server interface
Result of the command: "packet-tracer input Esterna tcp 8.8.8.8 12345 MY_PUBLIC_IP 8080"
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in  MY_PUBLIC_IP    255.255.255.255 identity
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: Esterna
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Anyone have suggestion?
14 Replies 14
cadet alain
in newer code > 8.2, the ACL must specify the internal IP and not the translated IP so replace this ACL:
by
access-list Esterna_access_in extended permit tcp any x.x.x.x eq www
access-list Esterna_access_in extended permit tcp any x.x.x.x eq 8080
where x.x.x.x is the internal IP you are forwarding, don't forget to apply the ACL inbound on Esterna interface with access-group command.
Also I suppose there is only one host you are port forwarding for ? so you must change the object network clause by specifying this host like this: http://networkology.net/2012/04/08/static-pat-port-forwarding-asa-83-84/
Then redo your packet-tracer with the internal IP as destination
Alain
Hi Alain, thanks for the answer.
Zabbix obj is already the internal address:
host 192.168.1.110
description Created during name migration
Anyway I tried also with:
access-list Esterna_access_in extended permit tcp any host 192.168.1.110 eq www
access-list Esterna_access_in extended permit tcp any host 192.168.1.110 eq 8080
But nothing.
If I do the packet-tracer with the internal IP I got (I don't know whitch port is used):
Result of the command: "packet-tracer input Esterna tcp 8.8.8.8 12345 192.168.1.110 8080"
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.1.0     255.255.255.0   Lan
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group Esterna_access_in in interface Esterna
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: inspect-ftp
Result: ALLOW
Config:
class-map global-class
match any
policy-map global_policy
class global-class
  inspect ftp
service-policy global_policy global
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (Lan,Esterna) after-auto source dynamic Server interface
Result:
input-status: up
output-interface: Lan
output-status: up
Action: drop
AND
Result of the command: "packet-tracer input Esterna tcp 8.8.8.8 12345 192.168.1.110 80"
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Result: ALLOW
Config:
match any
class global-class
  inspect ftp
Phase: 5
Type: FOVER
Result: ALLOW
Config:
Phase: 6
Type: VPN
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-status: up
output-status: up
Action: drop
The target of the "packet-tracer" needs to be the public IP address/NAT IP address rather than the real IP address.
That is why you are seeing that the initial Phases go through but it DROPs the packet in the RPF Check of the NAT rule. In other words it has matched no NAT rule in the way in but on the reverse direction it matches a NAT rule and is dropped.
I would imagine that your problem is overriding NAT rule that prevents the Static PAT from working.
You might have something likes this for example
nat (Lan,Esterna) source dynamic any interface
This would already prevent the Static PAT from working.
If you have the said configuration you should remove it and replace it as
nat (Lan,Esterna) after-auto source dynamic any interface
Adding the "after-auto" will move the Dynamic PAT rule (or whatever you might have, if you have it) to a lowest section of the NAT rules and therefore the Static PAT would now be on higher priority and would work.
- Jouni
Jouni, I got this nat rule:
Where into "server" there's also my internal IP that I want to be natted.
Anyway the packet-tracer results are always
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
It should be matching to a NAT rule before any ACL related drop could occur.
Can you share your NAT configuration.
Is that the output of a "packet-tracer" command that targets the mapped port of TCP/8080?
- Jouni
Yes is the output of:
My all NAT config is too long and I must clean IP/name ecc, but this internal IP is matched also by the group Server and this is the only nat rule:
Do you think the inactive nat rule can be a problem or are all skipped?
Another info, the other NAT on other pubblic IP is working well.
The most common reason I have seen for a Static PAT to fail is a Dynamic PAT using the same external interface IP that is too high in the priority of the NAT configurations.
At the moment it should be matching to some NAT rule before it could be dropped by an ACL as the UN-NAT Phase should be among the first Phases and if that went through then an interface ACL might cause a drop.
Maybe we could check another type of "packet-tracer" test unless its stopped by some interface ACL
packet-tracer input Lan tcp 192.168.1.110 80 8.8.8.8 12345
Lets see to which NAT rule this kind of packet coming from the LAN should match to. To my understanding it should match the Static PAT rule you have configured if its working correctly. Or it might match some wrong rule.
- Jouni
Result of the command: "packet-tracer input Lan tcp 192.168.1.110 80 8.8.8.8 12345"
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         Esterna
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: Lan
input-status: up
output-interface: Esterna
output-status: up
Action: drop
Is dropped by ACL and no NAT rule.
Well in this case it would seem to me that ACL is blocking this packet.
The ACL is checked first for the source and then the NAT for the source.
This works fine for my home ASA when I test with the same logic one of my Static PAT rules.
Since there is no NAT for destination in this case we wont be expecting any NAT rule before the ACL check.
CAn you for example make an ACL rule to the top of the interface ACL that allows this traffic of the "packet-tracer" and then try again.
If that doesnt go through then there either has to some global setting that prevents the connections or something going on that I can't really point out.
- Jouni
This is the output after insert the ACL that permit all traffic from 192.168.1.110
(I have change the NAT config by mapping 80 to 80 and not 8080 to 80)
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group Lan_access_in in interface Lan
access-list Lan_access_in extended permit ip object Zabbix any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Result: ALLOW
Config:
match any
class global-class
  inspect ftp
Phase: 6
Type: FOVER
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (Lan,Esterna) static interface service tcp www www
Static translate Zabbix/80 to PUBLIC_IP/80
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 7729899, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
That seems go through just fine.
But is the situation the same for the direction from External to Internal?
One thing that is very odd in your above output is the fact that this traffic is matching some FTP inspection rule which it really shouldnt.
Don't know if it has anything to do with this situation.
If we presume that all the related ACLs and NAT are configured correctly then I can't really see the problem. It wouldnt be the first time where a reboot solved this kind of problem. I just have not personally expirienced this kind of problem with Static PAT.
- Jouni
I've excluded also the inspection without luck. Tomorrow I'll try to reboot both firewall (HA setup) and hope solve the issue (I don't think).
This is a migration from version 8.0, maybe the auto migration of rules introduce some unexpected config.
Enrico.
It is possible that the automatic migration of the NAT rules during bootup has created rules that that cause this not to work.
I have personally always done the migration manually be converting the configurations myself. Naturally this causes some outage to network connections but I think its a better solution than getting a very messy/vague NAT configuration that you dont personally know.
From what I have read here on the forum discussion, it seems the ASA might create large amount of NAT configurations that might be useless in the new configuration format. And naturally how specific the NAT configuration was in the old software probably plays a role in how the configuration converts.
One question would be. Do you have any other Static PAT rules that use the "interface" IP address of the ASA "Esterna" ? You said that you have other NAT rules that are working. Are these perhaps using separate public IP address?
I would look for any NAT configurations in the existing configuration that use the parameter "any" at either the interface or the source network/host configuration section.
These might sometimes cause big problems for traffic forwarding.
- Jouni
Finally I got it working.
I delete all the "name object" in my config, do a clear xlate, and renamed the network-object used in NAT command and all is working.
I thought some name/network object during migration had some issue and conflict with nat.
So I confirm that it's better when migrating from 8.2/3 to 8.4 to start the config from scratch.
