I'm trying to login into my ASA 5520 ASDM IDM luncher, but when I put the ip address of the ASA, the username and the password into the ASDM launcher I'm getting "unable to launch device manager from 192.168.x.x.
can anyone help. I have read through the community solutions and everything being suggested did not work for me.
Please see the attached image of the message.
We need more information, what version of ASDM in the ASA , show version give information.
1. what java version available on your PC
2. have you setup http. ( change the IP as per the environment)
(config)# http server enable
(config)# http 10.10.10.0 255.255.255.0 INSIDE
(config)# username bandi password password privilege 15
https://10.10.10.10 << ASA IP to test working
Thanks Balaji,
The ASDM version is
Cisco Adaptive Security Appliance Software Version 9.1(5)21
Device Manager Version 6.4(5)
the version of java is 8 updare 271
I have enable the server, configure the ip address, username and password.
please see copy of the running config and show version output attached.
I look forward to your suggestion
config t
asdm image dosk0:/asdm-752-153.bin
config as mentioned other port config for the http server test and advise.
You need to specify the ASDM image in your configuration. Use this command in config mode: "asdm image disk0:/asdm-752-153.bin" (based on the directory output you provided).
Also, once you fix that, please confirm that you are accessing ASDM from a host on the 192.168.2.0 subnet.
Your ASA is set to allow only access from there as a result of this configuration line: "http 192.168.2.0 255.255.255.0 local-lan".
thanks Marvin,
I've configure the asdm image and can ping the ASA interface 192.168.2.1 from my laptop but still getting the same message.
When i tried to access the ASDM from java web start application i get the following also;
"Java Web Start is required to run ASDM, but it is not installed on this computer."
Though i already have java installed on the pc.
thanks for any useful idea.
First, try https;//asaip/ - is this works?
post java version here from cmd.
java -version
or refer below document
https://www.cisco.com/c/en/us/td/docs/security/asdm/7_8/release/notes/rn78.html#id_25476
Tahnks Balaji
When i tried the asa ip address - i'm asked to install java even though is already installed.
this is the java version
C:\Users\USER>java -version
java version "1.8.0_271"
Java(TM) SE Runtime Environment (build 1.8.0_271-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.271-b09, mixed mode)
i've looked at the documentation no luck.
looked forward for any suggestion that can help.
