04-09-2015 08:07 PM - edited 02-21-2020 05:26 AM
Hello everyone this the problem am facing with i, ASA 5520 boot perfectly led on POWER,ACTIVE,STATUS are solid green vpn is off because we are not using currently ,FLASH led comes on during post stage but after that it blinks green at every 30 sec - 1 min,we can't access the the asa using console the management port is shutdown any advice will be appreciated thank you.
04-10-2015 08:11 AM
when you power on ASA, do you see some activity on console?
If it is giving some error message, please post it.
04-11-2015 01:52 AM
nothing at all.
04-11-2015 01:59 AM
i will on Monday.
04-17-2015 03:39 AM
yeah the console port is the problem what can i do?
04-17-2015 05:33 AM
Do you see baud rates are correct? If yes, RMA would be needed
04-23-2015 04:39 AM
everything is correct and asa 5520 warranty period is over is there anyway to fix it.
