Posting here as the answers seems hard to find and/or create even more uncertainty.
We are considering deploying an active/standby pair on ASA 55xx-x with the CX blade, in multi-context mode.
There are rumors the CX functionality only works from inside->outside, not from outside-> inside. This is unexpected.
Secondly, I have heard CX functionality has some hurdles when running in mulit-context mode.
My questions:
- Does the CX blade works both ways, or do you need to select a direction?
- What are the details of multi-context and CX blade?
- Any hint on what policy to install since its either internal ASA, or through the blade. If through the blade, you need to select a policy.
- What are the caveats running the CX blade?
- Any proper clear document in which the theoretical functionality is explained?
Many thanks
