05-16-2018 12:45 AM - edited 02-21-2020 07:46 AM
I cannot get this to work.
What I want to do.
Host on Internet (any) --> FW (xx.xx.24.220:22) --> SSH-pi (10.10.50.65:22)
Host on internet connects with ssh to FW port tcp/22 and will then be forwarded to SSH-pi on port tcp/22.
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address dhcp setroute (DHCP ip = xx.xx.24.220)
interface GigabitEthernet1/8.5
vlan 5
nameif FW-VL5
security-level 100
ip address 10.10.50.1 255.255.255.0
object network SSH-pi-ext-ip
host 77.53.24.220
host 10.10.50.65
access-list outside_access_in extended permit tcp any object SSH-pi-ext-ip eq ssh log notifications
object network obj_any
nat (any,outside) dynamic interface
nat (FW-VL5,outside) dynamic interface
access-group outside_access_in in interface outside
05-16-2018 02:25 AM
Couple things before we dive into your issue:
1. Update your original post and hide the public IP you're using for the object network SSH-pi-ext-ip
2. With ASA using port 22 on the outside interface it might happen that you cannot use it for a port-forward as you need. I am not 100% it's not possible, some tricks might help but I would just use any other external port like 2222 and map it to my internal server on port 22.
Here's PF config as I see it:
host x.x.x.220
host 10.10.50.65
object-group service ssh_2222 tcp
port-object eq 2222
object-group service ssh_22 tcp
port-object eq 22
nat (outside,inside) after-auto source static any any destination static SSH-pi-ext-ip object network SSH-p service ssh_2222 ssh_22 unidirectional
05-16-2018 02:25 AM
your NAT is wrong for port 22, you need to nat the outside ntercface on port 22 to inside pi 22, from outside to inside
05-16-2018 02:34 AM
