ASA ACE syslog problem
Francois Bachelier
Community Member
I've a problem with syslog logging on my Cisco ASA 5510 version 8.2(1)
I need to:
- 1) log some ACL with warning level to log deny acces
- 2) log some ACL with informational level to log permit and deny acces (notification level log only deny access and not permit acces)
- 3) not log others ACL
For 1), I configured the syslog server with warnings level and i enabled the logging rules with default level (syslog default level)
logging enable
logging trap warnings
loggging host "interface" "host"
access-list "interface" extended permit ip any any log default
For 2), I enabled the logging rules with specific level (informational).
          access-list "interface" extended permit ip any any log 6 interval 300
For 3), I disabled the logging rules
          access-list "interface" extended permit ip any any log disable
My problem is that the syslog logging level bypass the ACL logging level.
Even if some ACL are configured with informational level, the ASA send only warnings logs to the syslog.
I tried to configure the syslog default level to warnings, to remove the ACL and then put it back again with the specific logging level but I still have the problem.
Thanks in advance for your help
Francois
Francois Bachelier
Community Member
Can someone help me?
As the syslog logging filter bypass the ACL logging levels, I have to configure syslog logging filter to informational to have informational logs for my specific ACLs.
Therefore, I have to many logs...
The solution to rebuid the ACL after having changed the syslog default level doesn't work.
My temporary solution is to configure the syslog logging filter to informational and to disable the useless syslog ID in syslog setup.
Thank's in advance for your help.
Francois.
were you able to solve this problem? i have the same issue. the no-log statement doenst work on the ACL line.
