ASA Act/Stby Failover question
pemasirid
We have ASA pair configured with Act/Stby. failover cables are connected via a switch as both units are located in two different locations. We have one issue when primary unit become active and reload the same box (primary unit) get always comes back as active unit. There is no preempt configured as this is single context.
As we know in normal situation when the active unit reloaded and it comes up it should remains as standby unless its configured preempt in multi-context scenario. However when we reboot the secondary standby unit, it remains as standby when it come up.
One thing we know as best practice the switch used for failover connectivity should not share with other data communication ports, but in our case we do not have a dedicated switch for failover connectivity alone.
Can someone figure out why the active unit become active again when it comes up after reboot.?
Thanks..
A typical reason for this behavior is when the secondary unit has less functional interfaces compared to the primary unit. Have you checked that both units are equally healthy?
mkazam001
Level 3
Level 3
Perhaps something to consider:
The LAN Failover link only requires a dedicated VLAN as opposed to a switch.
Azam
