Hi all,
Im following this document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#lanbas
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_active_standby.html#wp1097252
the scenario I have is the following:
Cisco VCS -inside- ASA-a -outside- Cisco VCS-E
1.1.1.1 2.2.2.1
I'm planning to configure active/standby with failover link crossover cable.
If I add a second ASA
It will be linke this:
1.1.1.2 ASA-b 2.2.2.2
| 10.10.10.2 (stateful link)
| 10.10.10.1
1.1.1.1 2.2.2.1
From document it only uses the outside interface.
[Question]
Do i need to specify my internal IP address to do failover as well?
From DOC:
In this example, the outside interface of the primary PIX is configured this way
hostname(config-if)#ip address 172.16.1.1 255.255.0.0 standby 172.16.1.2
Here, 172.16.1.1 is used for the primary unit outside interface IP address, and 172.16.1.2 assigns to the secondary (standby) unit outside interface.
