ASA problem with IPSEC VPN data not passing
I am facing a starnge problem .
I have attached the diagram that i could make best.
Now problem is that:
I can ping from 172.16.15.0 > 10.10.16.0/24( all the IP address)
I can ping from 172.16.15.0(any ip) > 10.10.16.22 ( single ip pass )
I can ping from 172.16.15.0(any ip) > 10.10.16.X ( all other ip except .22 fails )
I tried extended ping from router interface ip : 10.10.16.254 ( secondary ) to 172.16.15.0 ( all ip) and it is success.
The configuration and ACL ( Both side) seems to be ok, VPN Tunnel is also up thats why the data is passing and pinging.
Also we found that there are ACL hits in the router, But there is no ACL hits in the ASA ,also there is no duplicate ACL so there is no chance of hitting any other ACL.
Also single inteface in the router has been used for LAN as well as WAN and WAN connectivity is via wireless(ISP)
Plz find the config as below , As i can't share all the config and VPN details i am partially sharing the required one.
Router:
------------------ show version ------------------
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(15)T10                                             , RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 12:48 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SUZSOUTH-BGHALLI_WTG-TATANET uptime is 1 hour, 29 minutes
System image file is "flash:c1841-advipservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 236544K/25600K bytes of memory.
Processor board ID FHK135270VD
2 FastEthernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
interface FastEthernet0/1
ip address 10.10.16.254 255.255.255.0 secondary
ip address 10.100.134.2 255.255.255.0 secondary
ip address 121.243.2.154 255.255.255.252
duplex auto
speed auto
crypto map Outside-Map
ip route 0.0.0.0 0.0.0.0 121.243.2.153
ip access-list extended Site_B_map
permit ip 10.10.16.0 0.0.0.255 10.101.150.0 0.0.0.255
permit ip 10.10.16.0 0.0.0.255 172.16.15.0 0.0.0.255
ASA:
interface GigabitEthernet0/0
description ### WAN Interface ###
nameif Outside
security-level 0
ip address 122.184.59.100 255.255.255.224 standby 122.184.59.101
interface GigabitEthernet0/1
description ### LAN Interface ###
nameif Inside
security-level 100
ip address 10.102.3.15 255.255.255.0 standby 10.102.3.14
interface GigabitEthernet0/2
description LAN/STATE Failover Interface
interface GigabitEthernet0/3
nameif Outside-Backup
security-level 0
ip address 121.242.42.4 255.255.255.192
access-list ASA-Site-B-ACL extended permit ip 172.16.15.0 255.255.255.0 10.10.16.0 255.255.255.0
access-list ASA-Site-B-ACL extended permit ip 10.11.150.0 255.255.255.0 10.10.16.0 255.255.255.0
access-list ASA-Site-B-ACL extended permit ip 10.101.150.0 255.255.255.0 10.10.16.0 255.255.255.0
Route:
route Outside 0.0.0.0 0.0.0.0 122.184.59.97 1 track 1
route Outside 0.0.0.0 0.0.0.254 122.184.59.97 1
ASA Version: 7.2(4)
Any help is appreciated
Rupam
17 Replies 17
Try it from CLI, you can see if the action if VPN encrypt or VPN drop.  You should also see an increment on your interesting traffic ACL.
-skint
Thanks to all of you for sharing your ideas.
It seems that the packet for some of the remote device are nt reaching the remote router interface,
It may be a problem and we are planning to test the same.
Also at the remote end my router has oly one inetrface configured for LAN and WAn and Lan ip i have given as seondary and wan ip as primary to same interface.
.22 is a end host connected to the common switch where router and wireless device is connceted.
.22 is able to ping but the other ip cann't able to ping (.21,.23 etc)those are some power rating device, But from the Router LAN interface was able to ping the device the de the
Will disabling proxy arp in the router(remote) side help in this case
