ā11-04-2011 10:10 AM - edited ā03-11-2019 02:46 PM
I have a problem with a routing.
My ASA 5510 is at ip 192.168.1.20
I have alos a router on IP Adress 192.168.1.30
I have created static route on the ASA for network 10.1.1.0 and network 10.1.10.1 to the gateway 192.168.1.30.
Problem I cannot ping the 10.1.1.0 and 10.1.10.1 networks...
In the logging I get Inbound ICMP deny message
I have open everything in the inbound Inside Interface.
Why can't I reach those networks?
My computer's gateway is the ASA 192.168.1.20. Everything else is working fine (WAN to LAN and LAN to WAN)
Only the LAN to LAN thing blocks...
Thanks for your help.
ā11-07-2011 02:52 PM
my problem is exactly like this one:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml
But how come it doesn't work??
ā11-08-2011 06:22 AM
So far, I found that it seems to be a problem of natting. I've tried excluding inside traffic from natting but it blocks later on.
here's a screen shot of packet tracer and my config. Please help, I'm reaaly bumped out about this.
: Saved
: Written by enable_15 at 08:56:18.018 EST Tue Nov 8 2011
ASA Version 8.2(5)
hostname FW-SERVERS
domain-name logid.com
enable password nC1TgPA/j9j.bzQi encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.23.122 FTPServer
name 192.168.23.18 MailServer
name 192.168.23.3 VPNServer
interface Ethernet0/0
nameif Inside
security-level 100
ip address 192.168.1.20 255.255.252.0
interface Ethernet0/1
nameif outside
security-level 0
ip address X.X.X.X
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
no ip address
management-only
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
domain-name XXXX
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_Access_in extended permit tcp any host X.X.X.X eq ftp
access-list outside_Access_in extended permit tcp any host X.X.X.X eq https
access-list outside_Access_in extended permit tcp 67.22.232.0 255.255.255.0 host X.X.X.X eq smtp
access-list outside_Access_in extended permit tcp any host X.X.X.X eq pptp
access-list outside_Access_in extended permit tcp any host X.X.X.X eq 47
access-list outside_Access_in extended permit tcp any any eq 123
access-list outside_Access_in extended deny tcp any any
access-list outside_Access_in extended deny udp any any
access-list NAT0 standard permit any
access-list outside_1_cryptomap extended permit ip 192.168.23.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list Inside_Access_in standard permit any
access-list 101 extended permit ip 192.168.1.0 255.255.252.0 10.0.0.0 255.0.0.0
pager lines 24
logging enable
logging asdm informational
mtu Inside 1500
mtu outside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (Inside) 0 access-list 101
nat (Inside) 1 0.0.0.0 0.0.0.0
static (Inside,outside) tcp X.X.X.X ftp FTPServer ftp netmask 255.255.255.255
static (Inside,outside) tcp X.X.X.X https MailServer https netmask 255.255.255.255
static (Inside,outside) tcp X.X.X.X pptp VPNServer pptp netmask 255.255.255.255
static (Inside,outside) tcp X.X.X.X smtp MailServer smtp netmask 255.255.255.255
access-group outside_Access_in in interface outside
route outside 0.0.0.0 0.0.0.0 199.255.30.89 1
route Inside 10.1.1.0 255.255.255.0 192.168.1.30 2
route Inside 10.1.10.0 255.255.255.252 192.168.1.30 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.252.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.252.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access Inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.168.X.X source Inside prefer
webvpn
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
vpn-filter value NAT0
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
pre-shared-key LOGIS2SLOGIS2SLOGIS2S
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect pptp
inspect http
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:12b6abd11e12da8ecc8bcb3298f62ca7
: end
ā11-08-2011 04:20 PM
Good news, I found the problem
Adding those routes to the NAT 0 did the trick
