Showing results forĀ
Search instead forĀ
Did you mean:Ā
asa vti interface snmp statistics problem
hi,
my SNMP mgmt systems does not read interface traffic stats. Everything is on zero. What could be a problem?
br
9 Replies 9
Share the config
MHM
config is simple, nothing special
nameif TU1
ip address aaaaa
tunnel source interface outside
tunnel destination AAAAA
tunnel mode ipsec ipv4
tunnel protection ipsec profile PPPPPP
intereseting thing is that ther is no stats even over cli command
# sh int outside
Interface "outside", is up, line protocol is up
Traffic Statistics for "outside":
150225833416 packets input, 88955620772911 bytes
141435662470 packets output, 93475314152425 bytes
414327832 packets dropped
# sh int tu1
Interface Tunnel1 is up, line protocol is up
Hardware is Virtual Tunnel Description:
MAC address N/A, MTU 1500
IP address
Tunnel Interface Information:
Source interface: outside
Mode: ipsec ipv4 IPsec profile:
Not config of VTI config of snmp
Anyway
Did you enable trap linkup linkdown?
If no add this command and shut not shut the tunnel and check snmp
MHM
why would I do trap linkup linkdown? My mgmt system is reading stats for other interfaces without that command.
@DraganSkundric87318, of course, this doesn't make any sense )
But if you don't see stats in the CLI, you'd never get them via SNMP, right? Do you at least see "interface tunnel" via SNMP if you poll ifMib? Anyway, this looks very much like a software caveat, if you will, but I'm not aware of any enhancement requests here.
You can try to use CISCO-IPSEC-FLOW-MONITOR-MIB instead: https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-IPSEC-FLOW-MONITOR-MIB
Refer to cipSecTunnelTable and cipSecEndPtTable, but this is a bit complicated.
yes I can see interfaces over mgmt :-))  ... I just wandered if anyone else hit that wall
Just for troubleshooting' are snmp detect up down of VTI or not.
MHM
@MHM Cisco World, FYI, SNMP polling and SNMP traps are little bit different things )
Just wait @tvotna I knew that polling is different than trap
I need to see if SNMP totally not see anything related VTI.
From there we decide next step
MHM
