ASA5505 ASDM WON'T LAUNCH
Brett Erickson
I am at my witts end with this one and can't seem to find anything that matches my situtation. So I have an ASA5505 that I am trying to get the ASDM running on. I have done this before on other firewalls with no issue. Everytime I go to the url https://192.168.1.1 I get the prompt to accept the certificate which I do, then it just goes blank and the page freezes. If I try to launch it straight from the ASDM launcher it also just freezes. I have double checked my ssl encryption and made sure it has rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1. I am using asdm-714.bin image and have tried getting it run on the asa 8.2.5, 8.4.7 and 9.1.3 code and get the same results with each version of code I put on this device. I have also tried multiple computers, and both computer connect to my other firewalls just fine via url to lauch asdm or asdm launcher so I know it isn't a java issue with them. Is there something I am missing?? I have tried accessing the url using Safari, Firefox, Chrome and IE, all with the same results, accept the cert and it just hangs there and never displays the asdm launch page. Please Help!
43 Replies 43
JK, I can ssh, I forgot to add my "ssh 192.168.1.0 255.255.255.0 inside" ssh works fine now, just can't access the asdm
Here is the running config, am I missing somethine? I have checked it so many times.
ciscoasa# show run
: Saved
ASA Version 8.2(5)
hostname ciscoasa
domain-name test.local
enable password *removed* encrypted
passwd *removed* encrypted
names
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
shutdown
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
interface Vlan1
shutdown
no nameif
no security-level
no ip address
interface Vlan10
nameif inside
security-level 100
ftp mode passive
dns server-group DefaultDNS
pager lines 24
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.100-192.168.1.150 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username berickson password *removed* encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:28857584cf7b907dec6680534afadc01
: end
Hello
is 102 the internal PC?
Can you do a show flash?
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
yes 102 is my computer, and I can ping 192.168.1.102 (my computer) from the asa
ciscoasa(config)# show flash:
--#--  --length--  -----date/time------  path
    3  4096        Aug 23 2013 19:26:26  log
   12  4096        Dec 05 2013 14:42:34  crypto_archive
  116  410532      Dec 05 2013 14:42:10  crypto_archive/crypto_eng0_arch_1.bin
  117  410532      Dec 05 2013 14:42:34  crypto_archive/crypto_eng0_arch_2.bin
   13  4096        Aug 23 2013 19:27:06  coredumpinfo
   14  59          Dec 02 2013 10:09:30  coredumpinfo/coredump.cfg
  102  4792138     Jun 16 2011 15:52:06  anyconnect-win-2.5.3041-k9.pkg
  103  15390720    May 25 2011 19:14:58  asa825-k8.bin
  104  26772780    Apr 20 2011 16:26:46  csd_3.6.181-k9.pkg
  105  418765      Sep 28 2009 12:00:44  sslclient-win-1.1.4.179.pkg
  106  17790720    Dec 02 2013 09:50:44  asdm-711-52.bin
  107  22658960    Dec 05 2013 15:33:12  asdm-714.bin
  108  0           Dec 02 2013 10:09:30  nat_ident_migrate
  109  2768        Dec 02 2013 10:09:30  8_2_5_0_startup_cfg.sav
  110  1138        Dec 02 2013 10:09:30  upgrade_startup_errors_201312021009.log
  112  27408384    Dec 02 2013 11:06:02  asa903-k8.bin
  113  26984448    Dec 02 2013 11:06:42  asa913-k8.bin
  114  24809472    Dec 02 2013 11:46:20  asa847-k8.bin
256503808 bytes total (88137728 bytes free)
I just don't get it, why would it hit the ASA from my web browser then ask me if I want to accept the certificate and then once I accept it then it just does nothing?
Ok I have been trying to connect and checking the capture you had me setup, I saw this one.
79: 09:45:50.837481 802.1Q vlan#10 P0 192.168.1.102.58824 > 192.168.1.1.443: R 86402545:86402545(0) win 0 Drop-reason: (tcp-rstfin-ooo) TCP RST/FIN out of order
I can't see how it would be java related, I can't even display the web page that would then launch the java application.
Here is the version info if this helps anyone come up with any ideas, i am so at a loss right now...
ciscoasa# show version
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 7.1(4)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 4 mins 2 secs
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0    : address is 0021.5595.8321, irq 11
1: Ext: Ethernet0/0         : address is 0021.5595.8319, irq 255
2: Ext: Ethernet0/1         : address is 0021.5595.831a, irq 255
3: Ext: Ethernet0/2         : address is 0021.5595.831b, irq 255
4: Ext: Ethernet0/3         : address is 0021.5595.831c, irq 255
5: Ext: Ethernet0/4         : address is 0021.5595.831d, irq 255
6: Ext: Ethernet0/5         : address is 0021.5595.831e, irq 255
7: Ext: Ethernet0/6         : address is 0021.5595.831f, irq 255
8: Ext: Ethernet0/7         : address is 0021.5595.8320, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 20, DMZ Unrestricted
Inside Hosts                   : Unlimited
Failover                       : Active/Standby
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 25
Dual ISPs                      : Enabled
VLAN Trunk Ports               : 8
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has an ASA 5505 Security Plus license.
Serial Number: *removed*
Running Activation Key: *removed*
Configuration register is 0x1
Configuration has not been modified since last system restart.
I even just tried reformating my flash to see if that helped, I only put the asa825-k8.bin and asdm-714.bin back on it.
ciscoasa# show flash:
   41  22658960    Dec 05 2013 03:45:44  asdm-714.bin
   42  15390720    Dec 05 2013 03:46:22  asa825-k8.bin
    2  4096        Dec 05 2013 03:56:11  log
    9  4096        Dec 05 2013 03:56:37  crypto_archive
   50  4096        Dec 05 2013 03:56:47  coredumpinfo
   51  43          Dec 05 2013 03:56:47  coredumpinfo/coredump.cfg
255320064 bytes total (216899584 bytes free)
Still no luck, and double verified that my asdm-714.bin works on a different ASA running 8.2.5 code as well.
Julio do you have any other advice? Could it possibly be hardware related?
Yeah it does not make any sense.
What happens if you plugin a computer directly to the ASA and attempt to connect?
You have no idea how many Bugs are related to the Java version bud.
I am sorry if I am going around bud have you rebooted the box?? If yes then do the following:
Let's restart the HTTPS daemon
clear configure HTTP
clear configure asdm
Create your own permanent self-signed certificate and then
Configure HTTP/ASDM again,
Jcarvaja
Julio Carvajal
Computer is plugged directly into the ASA, quick question, when you say to create my own permanent self-signed cert are you just refering to the "crypto key generate rsa" command or is there more to it?
Hello Brett,
Wow this is getting crazy man,
Is there a way that you could downgrade to Java v6?
I know bud. I know.. This works with other firewalls but you have no idea how many times the solution of a ticket was that.
Hope you try it
Jcarvaja
Julio Carvajal
Yes, I am currently using Java 7 update 25, as it was the recommended on ciscos web page. But I will down grade to java 6 and let you know how it goes.
ha, this will be the death of me, I installed java 6 update 45, try to hit the web page in IE, accept the cert and then.....
NOTHING!!
I really do appreciate your help, I thought I was just missing something, that is why I was wondering if there was any type of hardware issue that could be causeing this as nothing I have tried has seemed to work.
